Torque Specs on Valve Covers
Old 05-29-2004, 08:40 PM
vetteguy75
Support Corvetteforum!
vetteguy75's Avatar
LA Events Coordinator
Default Torque Specs on Valve Covers
Got some new Edlebrock chrome valve covers. What are the torque specs for them. I torqued them at 15 lb and they seem VERY tight. No leaks or anything... :confused:
Old 05-29-2004, 09:11 PM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Torque Specs on Valve Covers (vetteguy75)
I'd say 15ftlb was more than enough. Those bolts will snap easily. My BB valve covers spec at 115 inlb
Old 05-30-2004, 11:14 AM
KenSny
KenSny's Avatar
Default Re: Torque Specs on Valve Covers (Jughead)
10 lb/ft converts to 120 lb/in
14 lb/ft converts to 168 lb/in
Depends on the cover. Aluminum would not take as much torque as a stamped Steel cover and if you use too much on Aluminum you will crack the hole area and if you use too much on a stamped steel cover you will likely warp/deform the edge.
To Torque Specs on Valve Covers
Quick Reply: Torque Specs on Valve Covers
