Fouled spark plugs
Old 09-11-2004, 10:33 AM
hurstolds
Cruising
hurstolds's Avatar
Default Fouled spark plugs
Replacing the second set of plugs in a week. I'm finding oil on the
threads and fouled to hell.
Any ideas?
Old 09-11-2004, 11:36 AM
CA-Legal-Vette
CA-Legal-Vette's Avatar
I have ideas but none that you'll like. Did the problem just start or has it been this way for a while? Is it on all plugs? Is it wet oil or soot?
If it is dry looking soot and just happened on all plugs, you're probably running rich. This is the easiest to fix. If it's actually oil, my guess would be worn rings.
My guess at least. Good luck.
Old 09-11-2004, 11:48 AM
GTR1999
GTR1999's Avatar
Received 2,618 Likes on 1,338 Posts
If they're wet with oil get a leak down and compression test ASAP. Fouling that soon with oil would show a nice blue gray cloud driving.
If black soot check carb settings and jet sizes,did you install a new carb recently?
gary
Old 09-11-2004, 12:07 PM
hurstolds
Cruising
hurstolds's Avatar
Default No Smoke
82 CF: I'm assuming it's running rich, at least I hope so. I've been
having trouble with it idling.
. I'll problably start with a compression test. Go from
there.
It has 99900 miles.
Old 09-11-2004, 12:59 PM
CA-Legal-Vette
Here's a thought. Does it start ok and then idle poorly after around 30 seconds? If so, try pulling off the air cleaner cover and look to see if you're flooding. This might explain both problems.
To Fouled spark plugs
Quick Reply: Fouled spark plugs
