LSA Swapped 86 Vert (in progress)
Hello everyone
I am in the middle of a Lsa install in my 86 convertible to be ready for slalom this summer!
Parts list/Progress/cost:
Lq4 block fitted with forged pistons and rods- at machine shop currently----$5000 all funds CND.....still waiting....june 14 2016
L92 heads rebuilt-complete..roller rockers...new valves ----$1800
LSA lower bought from ebay 5000 km takeoff----$750 ported for 102 tb, isolator installed
ZL1 Lid - new -----$400
solid isolator install ----$75...done
self ported snout to match 102 mm throttlebody(ebay one)--$200..done
107962 60lb siemens injectors----$450
LSA stock rail----$350
walbro 450 in tank---$200...done
aeromotive reg and guage ----$300...done
1/2" line ran for feed ss 3/8 return..$150...done
4L80E running as is no rebuild with stage 2 shift kit(stock convertor atm)---$1500
dana 44 swap - complete---$900 minus what i sell my D36 and suspension for done dana 36 sold $700
some sort of brake upgrade unsure of which yet ---tbd.....
DRM rear suspension brackets---$300 ....done
DRM brake bias spring---$30
Adjustable camber rods ----$300...done
Poly bushings everywhere--complete--$400
6 point hoop with removable door bars---$750...in mock up phase
corbeau a4 red pair---$1300.... deal found! $700 installed!
stage 3 brian tooley racing camshaft...love that chop!...$600
fab exhaust from c5 manifold to ss l88 system including making flanges ...$150...done
battery relocation to passenger under speaker compartment with aluminum sealed lid ,vented...done
the photo with the balancer shows the 1/8" clearance between LSA
balancer and rack and pinion just enough to get a belt down there, this is with an engine positioned forward 1 inch to clear the wiper motor and rear of blower which now has also just enough clearance
hood modification...plan atm..cut hood along both sides of mini cowl peel and raise to mimmick a toledo pro 2 3/4 ...wish me luck
side note : if someone were to do this using a stock cts-v lid or ls9 lid i think it would clear the stock hood .lots of room at the rear just not at the front which is where the zl1 lid is much to tall ...1"-1.5" too tall at the front
car is close to completion still waiting on my engine which went for balancing on wednesday last week
once i get that its assembly and install time
Cant freakin wait !!
no new updates yet but i will be fabbing the trans bracket to c beam this weekend i will be taking many photos i will post them i also will take photos of the modification to the motor mount cradles that is done
best of luck with your swap!
Epic build buddy, LSA blower. I could only dream.
wow, I can't believe the difference in the dana 36 to the 44. I have two dana 70 and a dana 80 (both disks) way to over kill for a vette.
I'm just collecting pieces for my swap. My build is on a tight budget and wont be anything exotic.
Sure hoping that my 700r4 holds the lq9 for abit.
WOW, That's going to be one sweet ride!
StarleX86Vert (01-06-2016)
Hi esham I do plan on keeping the a/c currently i have removed the condenser lines and dryer i probably will be putting in a small compressor and condenser out of something japanese but thats low down on my list
Awesome build buddy, what heads you going to run? I just bought a set of CNC ported LS3 and a LS9 cam for mine. I'm just going to run a FAST intake on my car.Hoping to break the 500HP mark for the engine, maybe that wishful thinking, probably be 400HP.
I am running L92 heads
Have you started your build or are you gathering parts currently?
not sure how good the cam will be NA. At some point I plan to put a turbo on the car. Summit had the cam on sale for $124. The heads cost me $680, with valve springs. Picked up a fast ls fuel injection system as well. I'm going to use a holley oil pan.
Not sure if I'm going to throw a stroker crank (408in) and some rods in it. I'm just collecting pieces. My car is a pretty solid runner. Not sure if the engine will make it into the car. Found a 78 vette for 3000, with a blown motor.
I am planning on Having the pan tig welded i have found a couple people on kijiji who are willing to do the job as i do not tig weld
thanks for the sandblasting tip
i plan on having all the mounting and oil pan fab work done this weekend and ill be sending it for welding
hows your build coming?
my 85 vette build is going very slow, still waiting on parts. Still on the fence if I'm going to use the LS9 cam. I bought the LS3 cnc heads, but the valve springs that come in the head are border line for the LS9 cam. Might just throw in the LQ9 engine as is for this year and use some 100-200hp NOS shot for extra power for now.
does the lq9 have the front cam sensor?my lq4 did not so i am having to buy a front timing cover in order to use the ls9 cam along with some stout springs
I'm going to run the FAST EFI 2.0 ls swap kit. FAST told me that the kit is designed to run the truck style cam sensor. You have to get another cable from them to run the newer front cover cam sensor.
For the LQ9 engine as is stock configuration but has the professional products intake manifold, billet fuel rail and 96mm cable throttle body. Not my best buy to date, but it was cheap.
Other mods are Holley cast LS exhaust manifolds, LS style MSD coil packs and Holley muscle car oil pan. GM corvette style front accessory kit, with AC.
I'm going to get it running on an engine stand prior to installing the engine into a car. Just hoping for a quick and simple swap out.
Next purchases is the EV6 injectors, TCI flexplate and a LS style starter.
just got the pan Back from welding looks good
just made another list about 17 items long until im running
Yes, it is and wasn't a good deal The TB didn't come with all the sensors. It was part a package deal. I regret buying both the intake and TB.
Ya there is definitely a long list of items to do the swap.
Congrats on getting the pan off the list. You going have to post pictures for us to drool on.
You watch the LSA build that they had on spike channel on the weekend? That engine was a monster
[QUOTE=Mike Holmen;1591578418]Yes, it is and wasn't a good deal The TB didn't come with all the sensors. It was part a package deal. I regret buying both the intake and TB.
You watch the LSA build that they had on spike channel on the weekend? That engine was a monster[/QUOTE
Nope i dont have cable but i tried to watch it on their website but it was terribly slow..
heres some more photos....i just started cleaning up the harness this weekend with all this nice weather we've been having im gettting anxious to get this rollin!
