Paint on my Paint!!
Old 02-04-2005, 12:33 PM
84Coyote
84Coyote's Avatar
Default Paint on my Paint!!
Hey, what should I do if I get paint on my paint job??
Old 02-04-2005, 01:07 PM
SilverBeast
SilverBeast's Avatar
St. Jude Donor '05
If it's just overspray, use a claybar and elbow grease.
Old 02-04-2005, 07:49 PM
84Coyote
84Coyote's Avatar
What if its paint that splashed up off the road??
Old 02-04-2005, 09:05 PM
TA
TA's Avatar
Clay bar
Old 02-04-2005, 09:06 PM
Kwikerthanu
Kwikerthanu's Avatar
St. Jude Donor '05-'06
If it's household paint like latex or oil based? Or was it lane marking paint? Any of these will come off with rubbing alcohol. Just remember to re-wax where you have cleaned.
Old 02-05-2005, 12:31 AM
dan6712cc
dan6712cc's Avatar
I drove over some wet road paint, that white stuff they use to paint the lines.. nothing could get it off, I clayed for hours with little success Then I tried goofoff, took everything off in a few minutes I was afraid it would take off the original paint on my car but it didn't. I've used it on other types of paint and it removed the original paint, but if nothing works I'd try this in a small spot and see if it helps. Just be careful, this would be a last resort.
Old 02-05-2005, 08:35 PM
CF6873
CF6873's Avatar
I have used lacquer thinner successfully to remove road line paint.
Old 02-05-2005, 10:38 PM
kwik_ta
kwik_ta's Avatar
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
... I drove over fresh yellow lines and sprayed the entire drivers side with little yellow specs on a bright red car... and nothing took it out. I ended up having to repaint the car.
To Paint on my Paint!!
Quick Reply: Paint on my Paint!!
