Trick Flow L98 Head and Cam Kits
Old 12-11-2006, 06:24 PM
tdf
tdf's Avatar
St. Jude Donor '11
Default Trick Flow L98 Head and Cam Kits
I notice that Summit Racing sells a couple of Trick Flow Kits (Alum Heads, Cam, Gaskets, seals , bolts, roller rockers etc.) that reportedly get the L98 to 350HP for Kit 1 and 400+ for Kit 2. $1600-$1700
Has anyone tried either of these mods?
Did you get the performance boost advertised?
What is the effect on emissions?
I have an 86 iron head L98 and I'm considering something like this mod for more power.
Tom
Old 12-11-2006, 06:55 PM
juanathandavid
juanathandavid's Avatar
perhaps the heads can handle the horsepower, but doesn't our factory TPI bottleneck any real hopes of achieving those HP numbers?
Old 12-11-2006, 08:20 PM
tdf
tdf's Avatar
St. Jude Donor '11
Default That's the question
That's what I'm attempting to find out. Is this mod a viable mod and does this it achieve those numbers? Someone must have tried it!
Old 12-11-2006, 08:57 PM
psychodiagnostik
psychodiagnostik's Avatar
I wonder how it would work with the superram intake.
Old 12-11-2006, 09:40 PM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Are these claims ever true? You'd think if it was that good, they'd be blurting out dyno sheets.
Old 12-12-2006, 01:31 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Sounds like a hellova a deal for $1,600.
Do they give out any specs on the cam(s)??
The stock TPI might not bring those numbers but a little mod work up top will.
Old 12-12-2006, 04:57 PM
rlane5
rlane5's Avatar
what is the runner size of the heads and the spec of the cam? The end results (performance and drivibility) revolves around that.
Randy,
Old 12-12-2006, 05:16 PM
gabezC4
gabezC4's Avatar
My GM mechanic buddy and his brother tried to persuede me into buying kit 1 for the $1600 out of Summit. We duscused it and I decided to keep the dough and invest it into another area for now. 350 hp is cool, but he did say that you had to adjust your stock TPI with a mod injection kit and get the exact specs for the cam and size of the heads. The other question was, would the cast iron block blow up with 350 hp? Maybe, who knows. Just buy the 330 hp "turn key" Chevy Sport engine for $4000 if you were to spend $1600-1700. Me, I'd just spend the $$$ for the completly put together, calibrated and tuned engine, but I ain't got the moola so I'll dream for now!
Old 12-12-2006, 07:15 PM
Makoshark67
Makoshark67's Avatar
Default Here Goes
I know I'm looking for trouble here, but in reality, If you have the guts to go non computer, you can make serious HP w/ the basic L98 smallblock. I build/built various HP levels Mouse & Rat Motors, and the one thing that WILL shoot you in the foot is trying to stay within factory TPI / Computer parameters an getting serious HP. The C5 gang have a different type of SBC to deal with so they typically pull bigger HP numbers. You gotta make a decision if you will settle for a stock configuration or if you want to go for it, and move outside the box. IF you want instant satisfaction - go nitrous (IF your mill isn't tired & trans is in decent shape) You can save $$$ this way any maybe buy some time to think through the right approach for you.
Corvettemike1967 aka Makoshark 67
Old 12-12-2006, 09:38 PM
Dominic Sorresso
Dominic Sorresso's Avatar
I'm using the TFS 23D heads on a Xfire. Its modded with roller cam, headers etc but its running 105mph.
To Trick Flow L98 Head and Cam Kits
Quick Reply: Trick Flow L98 Head and Cam Kits
