guys, you want to see a 8 t/b intake of mine ??
hi guys,
ld85 and conv90 kindly posted up my new pictures of my new 8 throttle body cross ram intake!
if you look in c4 tech/performance section and look under EMO-VET user name on first page there is two threads one says "hows this for a sick cam " , and the other thread is about " coolent port questions "
take a look any way guys
cheers
shae
cheers
shae
hi raysur,
how are ya!
thanks for the reply and link mate!
no videos yet mate,i just got the intake a couple of days ago!
cheers
shae
how are ya!
cheers
shae
i brought the dc&o 8 t/b cross ram intake for $ 3,300 aus dollars!
emo-vet
emo-vet
hi guys,
yeah thanks for the replys guys!
well i have dummy fitted it all up,cool,every thing fits nicely,
throttle bracket works well,map sensor relocated on fire wall,adj reg fitted on air pump delete bracket,fuel lines all fit and work out well,filters a good fit and not touching any where,the cut naca hood vents sit just beofre intake directly over the top and would let lots of nice air in,the intake has map chaneels built into each port underneath to run the map properly,also has own brake booster fitting at rear
plus the a/o forced air scoop/coupler in front bumper also,ait temp sensor located in nice spot,i have even modded up a i.a.c box and fitted it all up to run the idle air control sytem,msd small cap dist,msd remote coil on there way,msd wiring conv harnesses all ready,30 lb fms injectors fit up nicely,should abe all good.
as boschvette here on this forum has this intake also,he has gains of 50rwh all thru the rev range from it on his 383,11:1 comp,big heads,big cam e.c.t and doing 11.2 sec on the quarter mile and whipping stock c6 zo6 vettes *** as he has already come up against a c6 zo6 vette already.
so yeah all is looking cool guys,cant wait to hear the dam sucker,
cheers
shae
cheers
shae
