The mysterious Case of the Wobbling Rear View Mirror....
Old 09-09-2008, 08:43 AM
Randy Munson
Randy Munson's Avatar
Default The mysterious Case of the Wobbling Rear View Mirror....
Please help me solve this mysterious wobbling, shaking rear view mirror case! 1992 Vette coupe. My rear view mirror shakes like crazy whenever I hit the slightest bump in the road. Is there a way to tighten these bad boys up a little??? I gave the token glance at it hoping to see a set-screw or something but nada. Could it be that all the cars and landscape behind me are shaking and my mirror isn't??????? Many thanks once again to the experts out there! Oh, and while I'm writing, I went ahead and bought a set of KYB rear shocks for my 92. Thinking of putting them on myself. Any tricks or ? I need to know about here? Ride height issues?? Or is this a POC(thats, piece of cake folks)????
Old 09-09-2008, 08:52 AM
Goldcylon
Goldcylon's Avatar
Look again there is a screw
Old 09-09-2008, 09:26 AM
zr1fred
zr1fred's Avatar
If it's not the set screw on the base, it's the nylon insert on the ball pivots. For that there is no cure (that I know of).
Old 09-09-2008, 09:42 AM
xCCTer
CF JASOC Member
Support Corvetteforum!
xCCTer's Avatar
Location: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
with both of the above.
Tightening the small screw you can see behind the mirror glass when you adjust the mirror all the way out was loose on my '88.
Old 09-09-2008, 11:30 AM
Wayne88
Wayne88's Avatar
If the ball is loose, its time for a new mirror. About $100.
Old 09-10-2008, 07:12 AM
78pacer
78pacer's Avatar
I thought my Harley had shakey rear mirrors.........My '95 easily rivals that. Join the shakey mirror club!
Mike
Old 09-10-2008, 10:35 AM
Alan777
Alan777's Avatar
I tightened the screw, that helped a good bit.
Old 09-10-2008, 10:39 AM
Sweet 90
Sweet 90's Avatar
Same on my '90 It used to hurt my eyes just looking at it.
Reminds me of that movie where the Italian guy gets in his car and rips
off his rear view mirror and says "Whatsa behinda me is nota important"
or something like that(Cannon Ball Run????)
Jim
Old 05-12-2015, 07:43 PM
lectroglide
lectroglide's Avatar
Jim
ok but ya always gotta be on the look out for cops on your tail
Old 05-12-2015, 10:35 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
use red loctite
Old 05-12-2015, 10:50 PM
1993C4LT1
1993C4LT1's Avatar
Originally Posted by PLRX
use red loctite
Thanks Pete. Mine was loose like 3 months ago. If and when it gets loose, red loctite it is
Old 05-13-2015, 12:19 AM
johnnymo63
johnnymo63's Avatar
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Squirt Blue Loctite into the ball-pivot. That did the trick in my Nova.
Still firm after 4 years.
Old 05-13-2015, 05:07 AM
enventr
enventr's Avatar
When I replaced my original shocks (KYB) on my 95 the height seemed to be higher which to me should not make sense as I did not change the springs. The stock shocks that I replaced appeared lower but I did not take a measurement. The shocks are pretty decent as I use the car on weekends and do not race.
Old 05-13-2015, 12:16 PM
lectroglide
what does that have to do with mirros
Old 05-13-2015, 03:04 PM
DGXR
DGXR's Avatar
Did you read the original post?
Old 05-13-2015, 03:06 PM
enventr
enventr's Avatar
The op said he is putting on KYB shocks and is there any problems. Is there any ride height issues.
He had 2 questions the first one being the mirrors and the second one about the KYB shocks
Old 05-14-2015, 02:42 AM
Roys92BlackRose
Roys92BlackRose's Avatar
Rear shocks are a breeze. Jack up, remove wheel, remove one nut on the bottom and two bolts on the top, swap the top plate onto the new shocks, tighten the shaft nut to squish the rubbers and reinstall. Did mine in an hour. Shocks don't change ride height, only spring adjustment or modification can do that.
Old 05-14-2015, 08:05 AM
Bandit's C4
Bandit's C4's Avatar
Central PA Events Coordinator
St. Jude Donor '12-'13
Did you note the DATE of the original post?
To The mysterious Case of the Wobbling Rear View Mirror....
Quick Reply: The mysterious Case of the Wobbling Rear View Mirror....
