Weights, curb weight, axle weights
Old 12-16-2008, 02:46 AM
c4zf6nut
c4zf6nut's Avatar
Default Weights, curb weight, axle weights
Hi there,
I need to find information on the 1989 Corvette, curb weight (3229lb?), maximum permissible weight, front and rear axle maximum weights for 1989 C4 w/ ZF6 manual.
C4ZF6nut
Old 12-16-2008, 08:29 PM
Eddie & the Cruisers
Eddie & the Cruisers's Avatar
This won't give you all the info you wanted, but....
http://www.corvetteactioncenter.com/...9/89specs.html
Old 12-16-2008, 08:57 PM
StealthLT4
StealthLT4's Avatar
Isn't the max permissible written somewhere on the car? Haven't looked for it on my Vette yet, but my old car had a sticker in the door sill with tire pressures and max weight.
Old 11-22-2015, 09:35 AM
frusciano
frusciano's Avatar
CAN we find the lifetime of curb weights 4 corvettes all the years?
Love, Hugs and Kisses Rachel
Old 11-22-2015, 12:04 PM
c4cruiser
c4cruiser's Avatar
IF the car hasn't been repainted with maybe a color change, there should be a door sticker that shows the shipping weights for the front axle and rear axle and a total gross weight.
For my '87, the front axle weight is 1775 lbs and the rear axle weight is 1972 lbs. for a total of 3747 lbs. I believe the total cargo weight (driver, passenger, and luggage) is around 450 lbs and of that weight, the rear storage area should not hold more than 100 lbs.
Old 11-22-2015, 04:55 PM
frusciano
frusciano's Avatar
Hello c4 cruiser well thought r dream car [ affordable] 1985 we r trying 4 was lighter weight some where on the web my husband found a page with all the corvettes curb weights
I've looked but can/t find it
know the 1st generation is the lightest thought 1977 was the heaviest 2 all u corvette lovers Thanks xo Rachel
Old 11-22-2015, 06:13 PM
bb62
bb62's Avatar
Where does the extra 422 pounds come from? The curb weight of an '87 is 3325 pounds. I can't believe that even all available options would add that amount of weight. Also, the front/rear weight bias is more toward the frot of the car. No C4 ever had a 47/53 front rear weight bias. The published coupe weight bias is 51/49.
Old 11-22-2015, 08:09 PM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
The MVMA numbers are all in the Heritage Center Documents.
https://www.gmheritagecenter.com/gm-...tion-kits.html
Old 11-22-2015, 08:50 PM
frusciano
frusciano's Avatar
hi wvzr1 thanks learned so much on this everything I wanted 2 know think yes go ahead 4 the 85 Love, Hugs and Swirly Wet French Kisses! Rachel
To Weights, curb weight, axle weights
Quick Reply: Weights, curb weight, axle weights
