Door ajar light on -- Can you help?
Old 12-30-2008, 11:05 AM
cajuncorvette
cajuncorvette's Avatar
Default Door ajar light on -- Can you help?
Thanks for your assistance and time. I have an '88 C4 coupe, and the door ajar light flickers on and off with the door shut. When I open the door (driver's), the light goes off. Any ideas on how I might troubleshoot? repair? Thanks! Happy New Year!
Old 12-30-2008, 11:20 AM
geogolf
geogolf's Avatar
Default door
first thing is spray some pb blaster in the switches[push them in as you spray] and see if that solves the problem, most of the time it does. if not you might have to glue a penny or something similar where the switch hits so it will close all the way lot of guys have done this to solve problem.
Old 12-30-2008, 03:39 PM
Goldcylon
Goldcylon's Avatar
Duct tape a couple of pennies in the door jam area to allow the switch to make contact. Its a $25 replacement switch. The two bolts that secure the switch to the door screw into a metal backing plate. You will need to remove the door panel to get to the switch. If you try to pull the switch through the door you might be able to unclip the door switch clip harness but the backing plate probably will drop inside the door. Good luck
Old 12-30-2008, 04:42 PM
cajuncorvette
Default Question about switch location
I'm totally new to the Corvette. Can you tell me where the switch/contact is located? Is it on the door where the latch is, or in the door well where the hinges are? I'll try the pennies! Thanks!
Old 12-30-2008, 04:43 PM
BluRay
BluRay's Avatar
It is a small round black plastic button about in the middle of the door all the way towards the back near the latch.
Old 12-30-2008, 06:02 PM
Goldcylon
Goldcylon's Avatar
As stated.. See pic below
Old 12-30-2008, 09:43 PM
wmupaprmkr
Cool Hand Luke of W MI
Support Corvetteforum!
wmupaprmkr's Avatar
I had the same problem with my 92, except it would set off the car alarm when it flickered!
Good luck on the fix, they are not too bad to change out if you need to.
Old 12-30-2008, 09:57 PM
Hogan
Hogan's Avatar
Location: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
By chance did you have your hatch open? Mine interior lights stayed on after the bracket that holds the plunger bent.
Old 12-30-2008, 10:38 PM
Goldcylon
Goldcylon's Avatar
Old 12-30-2008, 11:25 PM
Rimcrew
Rimcrew's Avatar
LOL - this sounds soooooo familiar.
Old 12-31-2008, 12:15 AM
Goldcylon
Goldcylon's Avatar
Its the voice of experience from most C4 owners
Old 12-31-2008, 11:08 AM
Iroc57
Iroc57's Avatar
Stick a piece of felt(small round self stick furniture pads) over the plastic spot that it contacts on the door frame. Cheap and easy fix
Old 01-01-2009, 12:33 AM
Eddie & the Cruisers
Eddie & the Cruisers's Avatar
Well its 11:30 here on new year's eve and I feel a little silly.
Tell the jar its not a door, but a Mason!
To Door ajar light on -- Can you help?
Quick Reply: Door ajar light on -- Can you help?
