Ignition and Pick-up Coil Matching
I've had intermittent start problems(with no spark) for years and need advice on the pick-up coil and ignition coil.
Service manual says : "Intermittent no-starts could be the result of incorrect polarity between the ignitition coil and the pick-up coil. The color of the pick-up coil connector has to be yellow of one ignition coil leads is yellow. If the ignition coil has w a white lead, any pick-up coil connector except yellow is OK"
From: http: //members.shaw.ca/corvette86/Ig...System-EST.pdf
I checked and my pick-up coil is yellow (on the N connector) and green (on the P connector) which is not what the picture shows (yellow on the P) on above link ... and my ignition coil is red/black and white.
So do I need to change my ignition coil to one with yellow wires? I'm confused in that the pick-up coil is yellow but not on the 'P' connector and there's no mention of this anywhere (always yellow on the 'P' connector).
paul
paul
It's an '89 all stock but the inginion coil has been replaced.
I'm thinking of just getting a new accel distributor ACC-59107C ($149) which has a pick-up coil in it.
I'm sure this is too subtle an issue - since there the confusion that the current pick-up wiring (yellow on the N-connector) just isn't covered anywhere. ANy thoughtsd will help,
thanks
thanks
Maybe it's been forgotten over the Years, but it's covered - as shown in the Service Manual - in most publications dealing with the HEI. Yes, you need the correct colored wires! Most of the aftermarket suppliers required this info (at one time) before they would sell you a new one. Go to NAPA and describe what you need - a competent counterperson should be able to find it.
As to your intermittent no start - it may have nothing to do with the pickup coil - in fact it would be somewhat unusal because if the polarity is wrong, the spark is too weak whether it starting or running - But most will show a spark when you crank it. No spark is no reference which would indicate a wiring problem - particularly if it's intermittent. After that, I suspect the injectors or the CTS signal. Check injector coil resistance hot/cold. Check the CTS signal with a scanner after it's sat overnight. It should be close to ambient.
Thanks for that advice about the pick-up coil - anybody know why the polarity would give a weak spark ... I'd assume it either detects or not magnetically.
Like a doof I bought the accel 59107C distributor and iot has vacuum advance - what '89 has vacuum advance. ughh. Free shipping ... but that's one way.
More info:My car has never stalled or given a rough ride. It has in the past had intermittent start problems (crank but no spark) so I replaced everything (rotor/cap/terminal boards) all but the pick-up coil. After i replaced the terminal boards the car was fine for 2 years - but the left me starnded last week. Only way to styart was to re-grease the ingnition module - which is saying just messing with all the stuff. It was frustrating to then see that the pick-up had a yellow wire but onb the N connector. Manual says yellow on pick-up coil 'P' connector with ignition coil with a yellow - but nothing about yellow on the 'N' pick-up coil.
Red herring perhaps - but I'll replace the entire distributor for peace of mind. I convinced myself that if I get +12 V ignition to the distributor and there is no spark (no ECM codes either) then all's that's left is the pick-up coil - otherwise if the pick-up coil was OK, then the HEI could run even without the ECM. The only catch there is it's an intermittent pick up coil (I did a resistive wiggle test and it was a solid 800 ohms) then why it never stalls?
Any advice will be appreciated.
