Windshield Reveal Molding
I need to replace my windshield and need the outer reveal moldings and can only find a left side from ecklers and not sure if its correct. Can anyone help me locate these 3 moldings? Just to be clear they are the small metal molding that are black that goes around the windshield
Long out of stock and discontinued. HARD to find . Yes, they should be replaced with new windshield but 90% of the time, a good windshield place will and can re use your old ones. I have had several c4 windshields replaced with it reused.
Received 1,401 Likes
When I had to have my windshield redone this part was very difficult for them to order, and very expensive.
If you take your time, the moldings are not a problem to get off. You need a good scraper and a putty knife to get underneath them so you don't bend them.
A reputable glass installer should have no issue with them.
The last pricing I saw on these 3 pieces was in the high $300.00 range. Finding new ones are almost impossible and good salvaged ones are about the same. Find a shop that can remove them with out damage. Good Luck
