Mo's Electric Corvette- Lot of Pictures
Old 07-10-2015, 01:34 PM
  #381
STEVEN13
STEVEN13's Avatar
Too
Thanks for the update!
Old 10-16-2015, 11:54 PM
  #382
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
Mo,
Any updates?
(I love this project )
Old 10-18-2015, 01:34 AM
  #383
Mo_Bandy
Mo_Bandy's Avatar
Originally Posted by ghlkal
Mo,
Any updates?
Funny you should ask..
To cut to the chase I have purchased a set of 11" motors to go into the car... They will also attach to my shortie powerglide. The motors were in a EV drag car "Renegade" from 2006-2011 was running the quarter in over 100 mph... Now finding a hime in my vette, they still need cleaned up a bit but can you say TORQUE?
Couple to transwarp
New Le mans Lights
Trophy for Most Unusual car...
MO
The following 3 users liked this post by Mo_Bandy:
FASTAZU (10-18-2015), Frizlefrak (10-18-2015), MavsAK (11-28-2015)
Old 10-18-2015, 12:58 PM
  #384
Raidmagic
Raidmagic's Avatar
This is just fantastic!!
Old 10-18-2015, 04:48 PM
  #385
Frizlefrak
Frizlefrak's Avatar
Mo Amps.
Don't get on here much anymore since I'm Vetteless, but it's good to see this car's progress....
Old 10-18-2015, 04:54 PM
  #386
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Originally Posted by Frizlefrak
Mo Amps.
I got a really nice 86 for sale
Old 10-18-2015, 05:04 PM
  #387
Frizlefrak
Frizlefrak's Avatar
That's how it always starts....
Old 10-18-2015, 06:01 PM
  #388
1993C4LT1
1993C4LT1's Avatar
Get another C4
Very cool Mo
Old 10-20-2015, 02:18 AM
  #389
Mo_Bandy
Mo_Bandy's Avatar
Frizzle come on buddy time to get another one
Thanks everyone for the compliments.
So these pictures aren't as good as i would like, but they give an idea the size comparison og the 9" versus the new 11" motors.
The new are the brighter red I have to cut about 2 inches off the shaft for the transmission.
11" on the top you can see the shortie Powerglide
Measuring out the length, the new drive train is about 3 inches longer
I will keep the photos coming if there is an interest...
Mo
Old 10-20-2015, 03:12 PM
  #390
Dt86
Dt86's Avatar
Originally Posted by Mo_Bandy
I will keep the photos coming if there is an interest... Mo
Heck yeah! This is one of the coolest threads going.
Old 10-20-2015, 05:17 PM
  #391
JrRifleCoach
Ditto
Old 10-21-2015, 09:59 AM
  #392
zwede
zwede's Avatar
Sorry for not paying attention, but are you running AC or DC motors?
Old 10-22-2015, 03:52 AM
  #393
Mo_Bandy
Mo_Bandy's Avatar
Hi Zwede.
I'm running DC the motors are run in parallel at 170 volts and max of 1000 amps ea, (2000 Amps) or about 340Kw ~ 380 Hp at 85% efficiency. Somewhere from 833 ft/lbs of torque through about 600 at 4500 rpms
For the rest following the post I managed to trim the shaft on the Transwarp tonight so the 11" drive train is now ready to install.
I will have a few pictures tomorrow.
MO
Old 10-22-2015, 08:30 AM
  #394
STEVEN13
STEVEN13's Avatar
Wonder how quick in the 1/4 mile these new motors are capable of.
Steve
Old 10-25-2015, 01:58 AM
  #395
Mo_Bandy
Mo_Bandy's Avatar
Steve
I'm guessing high 13's low 14's
MO
Old 10-25-2015, 02:10 AM
  #396
Mo_Bandy
Mo_Bandy's Avatar
And so it begins...
In she goes.... Barely enough room to roll it down the tunnel... it is too long to drop from the top.
Can you say fill the engine bay? I still need to fabricate the front motor mounts...
Rear cross member installed and rear trans mounts are in.
I need to install the driveshaft and reconnect my torque bar, then concentrate on relocating the controller, and a few things under the hood and should be back on the road.
Enjoy !
MO
Old 10-25-2015, 08:58 PM
  #397
ghlkal
ghlkal's Avatar
that should provide just a little bit of torque
To Mo's Electric Corvette- Lot of Pictures
Old 10-25-2015, 11:13 PM
  #398
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I'm surprised that the SMC floor can take all that weight! Looking sweet though!
Old 10-26-2015, 03:59 AM
  #399
Mo_Bandy
Mo_Bandy's Avatar
Hi Tom.
Yes this was a concern I had as well..
So I reinforced the top side of the floor panels by sandwiching the SMC with 2 1/8" thick x 6" wide x about 18" sections on each side to spread the weight around, and of course the cross member below. It is VERY solid...
MO
Old 11-05-2015, 01:50 AM
  #400
Mo_Bandy
Mo_Bandy's Avatar
Sorry folks it has been a few weeks since the last updates...
So a few cool things going on.
The motors are in and I have had them driving the back wheels, have the tach working, I purchased a heat sink cooler for the controller to replace the older trans cooler with the fan, replacing the older 600W DC/DC converter with a 2KW Auxilary power supply from a Chevy Volt. The older DC/DC converter could not keep up with the energy draw. Also have the forced air bands for the 800 CFM forced air fans to the motors to allow running higher currents for a longer period of time...
Deraler Dual Pass Heat Sink Cooler for the Zilla Controller .
Volt Auxiliary Power supply takes 360VDC and drops it to 13.6 VDC to charge the battery at up to 170 Amps
The forced air cooling bands for the motors to allow forced air to cool and help reduce Zorching under High Amp draws.
One of two 800 CFM blower motors that will force air into the motors
View thus far from the driver's side, Zilla Controller mounted the the front motor
Passenger view the open gap on the front of the motor exposing the brushes will be covered with the cooling bands
Controller wired up to the motors
Passenger side motors wired up 2/0 gauge wire
Enjoy!
MO
ghlkal (11-07-2015)
Quick Reply: Mo's Electric Corvette- Lot of Pictures
