C4 Dymag Chronology
C4 Dymag Chronology
You don't often see all 3 generations of C4 Dymag wheels together:
Gen 0 - 16x9.5, '87 Callaway Twin Turbo Corvette - 16.25lbs, 6 5/8" BS
Gen 1 - 17x9.5 flanked by 17x11, '88+ Callaway when scripted 'Callaway' or Challenge when scripted 'Corvette' - 18.20lbs, 7" BS on both 9.5's and 11's
Gen 2 - 17x9.5, Dymag aftermarket, 20.4lbs, 7.0" BS
Received 3,043 Likes
St. Jude Donor '05
Lotsa $$ sitting right there.
Take the middle row please.
Location: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
My buddy Evan has the Gen 2's on his white '85. I like both the Gen 1's and 2's, but I didn't know there was a Gen 0. I'd love to get a set of the Gen 1's with the 11-inch rears for my Z.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Interesting they got significantly heavier over time.
For some it may be hard to believe, but a ~4 pound difference per wheel (Gen 0 vs Gen 2) is easily felt. Even 2 pounds is noticeable.
The 16" gen 0 were light, but the tires are heavier (more sidewall) - the gen 0's and gen 1's are about the same weight for the rim + tire. The gen 2's are a couple of pounds heavier. They feel a little more substantial and, I believe, were made for bigger brake clearance.
Does anyone know what options for center caps are available for Gen IIs in 9 1/2" and 11" wide?
I see in the photo that OEM caps that appear to be like the 86, 88-90 MY and I have some of those. It fits the 9 1/2", but does not fit the 11" wheels. I should say it fits, but does not lock in with the clips like it does on the 9 1/2". I also tried a set of the black caps for 84-85 and those also fit the 9 1/2" wheels, but not the 11".
It's a little confusing and I would have imagined that the both of them would have the same center cap mounting if both Gen IIs.
Thanks!
Thanks!
I see in the photo that OEM caps that appear to be like the 86, 88-90 MY and I have some of those. It fits the 9 1/2", but does not fit the 11" wheels. I should say it fits, but does not lock in with the clips like it does on the 11". I also tried a set of the black caps for 84-85 and those also fit the 9 1/2" wheels, but not the 11".
Thanks!
Thanks!
Thanks Brett. I do have two sets from him and working some issues with too small, but looking at other options too. He made a custom black set for me. I was trying to mount them today and ran into the issues so seeing what else is out there that might work. I'm not sure why the factory one's fit the 9 1/2", but not the 11" with the clips on the back side.
Thanks!
Thanks!
