Door insulation
Old 06-20-2011, 07:58 PM
Tony A.
Tony A.'s Avatar
Default Door insulation
Corvette Central sells the door insulation kits that were stock on late C4's, 92-96. The preformed kit is only $22 and claims to reduce road noise considerably. I've got an 88 Vert and do experience alot of noise through the door.
Any opinions on this kit?
http://www.parts123.com/parts123/yb....5Z5Z50000050F#
Old 06-20-2011, 10:18 PM
Joe B.
Joe B.'s Avatar
I had to take the door panels off for mirror removal so I put the foam in while I was at it. I can't say I noticed a "considerable" reduction in road noise, but the doors do have a more solid sound when I close them.
Old 06-21-2011, 10:42 AM
tlong
tlong's Avatar
They are wafer thin. Maybe help a little but not much.
Old 06-21-2011, 07:55 PM
HlhnEast
HlhnEast's Avatar
The PO had these and never installed them. When I was working on the doors I went ahead and installed them. They did cut the noise and made the doors sound a lot more solid. I dont know how expensive they are but if you have the panels off go ahead and get them. Any lessening of road noise is a plus.
Old 06-22-2011, 01:16 AM
oldalaskaman
oldalaskaman's Avatar
i used Dynomat (Fatmat), thruout entire car including doors, its peal and stick, got rid of all door noise, ground noise, tire noise, and if I listen close, I can hear the flowmaster exhuast, air is ice cold also.
To Door insulation
Quick Reply: Door insulation
