Removed my shift indicator console(automatic) only 1 bulb but 2 sockets??
Old 03-01-2012, 12:17 AM
porshapower
porshapower's Avatar
Default Removed my shift indicator console(automatic) only 1 bulb but 2 sockets??
Hello I am cleaning up the interior a little and adding a new shift boot on my 88. Noticed when I lifted off the little console cover(that houses the PRND shift indicator) that there is a location for 2 light bulbs but I only have one? There is a location by the "P" which has no bulb and there is a location by the "1" where I do have a bulb? Should there be w bulbs there? Thanks in advance for the help! Nel
Old 03-01-2012, 01:31 AM
Cliff Harris
Cliff Harris's Avatar
I took my console top off recently and noticed the same thing. No bulb in the front location. It seems to have worked OK this way for 26 years so I guess I'll leave it alone.
I have been replacing my interior bulbs with LEDs, so that could happen here.
Old 03-01-2012, 02:15 AM
Joe C
Joe C's Avatar
my 85, 90, and 96 are configured the same way - one bulb.
Old 03-01-2012, 02:19 AM
Chewch87
Chewch87's Avatar
One Bulb in my 87 as well.
Old 03-01-2012, 02:44 AM
SQUIRMIN VERMIN 84
SQUIRMIN VERMIN 84's Avatar
Location: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Same here in my '84.....one bulb, two sockets. Someone at Bowling Green have a slow learning curve?
Maybe hired one of them Canadian ilegals......
Old 03-01-2012, 10:06 AM
oldalaskaman
oldalaskaman's Avatar
I installed two in mine (splice) makes it nice and brite, but not to brite.
Old 03-01-2012, 01:53 PM
porshapower
Thank You Guys for the responses! I was ready to start tearing the car apart to look for this other bulb and wire harness I wonder what the malfunction was on that one..maybe they were trying to keep the weight down to make the car faster
Old 03-01-2012, 01:54 PM
porshapower
BTW...I like the splice idea...maybe if I ever come across another wire/bulb like this one I will do the same.
Old 03-01-2012, 02:28 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I retrofitted a 4l60e into my 84 which came with a 4+3. I assumed there were 2 bulbs in the cover and wired it accordingly.
Old 03-01-2012, 03:59 PM
Mr. Peabody
Support Corvetteforum!
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
Naw it's just a spare socket in case you lose one.
Old 03-01-2012, 04:17 PM
85vet
85vet's Avatar
Cruise-In V Veteran
I did the same thing when I installed the 700r4.
Old 03-01-2012, 05:44 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Another thumbs up for 80s GM engineering
Old 03-01-2012, 06:09 PM
nutz4c4
nutz4c4's Avatar
Maybe this guy??
Old 03-01-2012, 06:21 PM
dukeallen
dukeallen's Avatar
Originally Posted by nutz4c4
Maybe this guy??
I heard he goes down to mehico now because it's easier to get over the border
Old 03-01-2012, 06:25 PM
nutz4c4
nutz4c4's Avatar
You know those felines are sneaky....Just gotta watch out for the Taco meat.......Oh the TMC...
Old 03-01-2012, 07:11 PM
RICEKILA
RICEKILA's Avatar
Location: Beautiful Down Town "SWINDLEHURST" Long Island NY
Pix's of missing bulbs
Old 11-29-2012, 08:05 PM
thomasbordercollie
1st Gear
thomasbordercollie's Avatar
mine has the one bulb, but a wire that could be used for the second socket. It had no bulb holder...?
To Removed my shift indicator console(automatic) only 1 bulb but 2 sockets??
Old 11-29-2012, 11:23 PM
Cliff Harris
GM probably used the same reflector/bulb combination on multiple cars and put in the option to have the bulb at the other end.
Old 11-30-2012, 07:37 AM
JoeUser
JoeUser's Avatar
Mine's just bright enough with the one bulb. I imagine that if two were in there it would be obnoxiously bright (and probably distracting or annoying).
Old 11-30-2012, 09:11 AM
Joe C
Joe C's Avatar
- i also thought that the same part could be used in the RHD export by just rotating the assembly 180. i've never seen a RHD console though, and do not know exactly how the console is configured - if the indicator lens is on the right or left of the shift lever. also, it very well could be that during early c4 development, it was decided that one bulb/socket was sufficient. eliminating the additional bulb/socket from C4's over the life of the program, even if it was only $1 per unit, would have saved over $350K.
bullguts (09-27-2016)
Quick Reply: Removed my shift indicator console(automatic) only 1 bulb but 2 sockets??
