C4 Carpet
Old 08-21-2012, 10:28 AM
TripsVette
TripsVette's Avatar
Default C4 Carpet
My apologies if this has been discussed before. I did a search and couldn't find an answer to my issue.
Recently my heater core on my 1994 sprung a leak. Before I could get home, I had anti-freeze all over the passenger side carpet.
I've tried to clean it, but it just won't work... so, while I have the heater core being replaced, I thought I'd have new carpet installed.
Since I'm not a wealthy man, I found a passenger side piece of carpet the color I need for a 1993 on ebay. Will the passenger floor board carpet from a 1993 fit in a 1994? Logic tells me it will, but I thought I'd check with you guys.
Old 08-21-2012, 10:36 AM
ejscarfo
ejscarfo's Avatar
It should be the same. You can go to one of the vendors and check what they sell to get the years of application to be sure, but I'm pretty sure you'd be good.
Old 08-21-2012, 10:40 AM
TripsVette
TripsVette's Avatar
Thanks for the help!
Old 08-21-2012, 10:50 AM
Siveck
Siveck's Avatar
I think that the cut of the carpet changed between 93 and 94. The 94 has more of a plush cut as opposed to the earlier cut pile?
Old 08-21-2012, 11:07 AM
dukeallen
dukeallen's Avatar
I think you'll be safe, and any slight differences won't even be noticed.
Just don't go for any 70s **** carpeting.
Old 08-21-2012, 11:18 AM
VetteMed
VetteMed's Avatar
94 went to "truVette" style carpet, which is a finer material. However, there's so little of the footwell carpet exposed, between the seat and the floormat, that it's essentially a non-issue.
Old 08-21-2012, 11:30 AM
TripsVette
TripsVette's Avatar
My thinking also. By the time I buy mats, the floor carpet will hardly exposed.
Old 08-21-2012, 12:09 PM
TripsVette
TripsVette's Avatar
Gracias for everyone's help.
To C4 Carpet
Quick Reply: C4 Carpet
