door panel
Their are ribs along the top of the panel that may be broken. Is that where it's loose?.
Hangs at the top and uses the plastic rivets on the bottom. Like hornet said, the ribs along the top of the panel are probably broken. There are a lot of posts here on that issue.
Cruise-In II Veteran
The plastic panels on my "new" '88 were both cracket; I repaired them with some fiberglass screen & JB Quick.
One panel has come loose again. The "fix" for it will be to get two "L" shaped metal pieces at the local hardware, cut down one leg to be just a little longer than the existing metal ribs along the door top and attach the "L"s to the top of the door. These project up just enough to keep the weak plastic panel from springing off.
common problem along with floppy visors etc
