Turn signal / Dimmer switch replace
Old 08-15-2013, 10:04 PM
ercriss
ercriss's Avatar
Default Turn signal / Dimmer switch replace
I'm trying to repair a turn signal/dimmer switch. I can turn on the LH signal but not the right. I cannot dim the headlights. This might be two different problems.
I've already been down the steering column to the multifunction switch inside the column. this appears good. I can "manually" trigger both left and right signals. This part is NOT needed. (see below)
This piece alongside the column is what I think I need (see photo below). It is where the turn signal stalk/shaft snaps into and "actuator" that operates the switches. What is the name or part number of this actuator?
Has anyone down this repair before?
Old 08-15-2013, 10:43 PM
GQ-ROD
GQ-ROD's Avatar
It's possible that the turn signal flasher relay is bad, it's actually 2 relays in one, one relay operates the left side, the other relay inside the same housing operates the right side, one side can still work while the other doesn't, check that first it's cheap before going too deep into the column.
Oops just read that you could manually activate the turn signal on both sides, you may be right on that part, don't know the name of it though.
Old 08-17-2013, 07:14 AM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
I'm guessing the image of the TS switch is NOT from your car. Is it? It's missing a cancelling spring so I guessed you're just using it from another source. In your second snapshot the section the TS lever attaches to is the "wiper switch/pivot" and it's likely what you need and maybe more.
I was just sent a column "on approval" and I should have anything that you need. There's a dimmer actuator that operates off of the pivot that if not broken is just out of place. Is the stalk quite loose and wobbly? I haven't even opened the box the column parts are in yet but I can and send snapshots of what I feel you need. I'm quite familiar with these columns.
PM me your email address and I'll get some snapshots later in the day for you.
Where are you located?
Old 08-17-2013, 09:11 AM
ercriss
ercriss's Avatar
I'm pretty sure I need #23 or #24. Most likely #23.
Old 08-17-2013, 09:54 AM
SeeFourSix
SeeFourSix's Avatar
I have to do the exact same repair... I have the exact same symptoms. From my research, it's #23 that fails. (wiper switch)
Old 08-17-2013, 09:58 AM
Hooked on Vettes
Hooked on Vettes's Avatar
http://forums.corvetteforum.com/c4-t...rn-signal.html
Old 08-17-2013, 10:19 AM
ercriss
ercriss's Avatar
YES!!! This is my exact issue. I actually still have the guide piece that broke off as some in these photos. That pivot piece is what I need. still can't find it online to purchase. 4th and 5th photos down.
Old 08-17-2013, 11:34 AM
SeeFourSix
SeeFourSix's Avatar
Check ebay. I found them for $79 shipped new.
Old 08-17-2013, 10:26 PM
Hooked on Vettes
http://www.ebay.co.uk/itm/Wiper-Swit...d=511334245457
To Turn signal / Dimmer switch replace
Quick Reply: Turn signal / Dimmer switch replace
