water pump
10-04-2013, 01:34 PM
water pump
for an `87, the original water pump, aluminum or cast iron?
10-04-2013, 07:15 PM
10-04-2013, 09:41 PM
starting to see coolant on garage floor. can`t tell where its coming from yet. damn, does the a/c compressor have to come off?
10-04-2013, 09:46 PM
Quote:
Originally Posted by
tntwolt
But you can pull the compressor and hang it out of the way somewhere without disconnecting the lines; no regas needed
10-05-2013, 04:14 PM
tntwolt
The compressor mounting bracket is attached to two studs that hold the water pump on the block, so yes.
10-05-2013, 06:52 PM
I like those edelbrock water pumps heavy duty better flow alittle bit more cash but worth it IMO
