1989 headlight open timing
Old 06-16-2015, 05:48 PM
Went
Went's Avatar
Default 1989 headlight open timing
Hi, I replaced the headlight motor gears on the left side. The headlight opens like there's no tomorrow. But it opens just a tad later than the right side. The right always comes up first. Is there an adjustment for this? Not such a big deal...just the picture straightener in me doesn't like it.
Thanks, Terry (Went)
Old 06-16-2015, 06:01 PM
antfarmer2
antfarmer2's Avatar
Good luck
Old 06-17-2015, 04:04 PM
Went
Went's Avatar
Is the opening not adjustable at all or is it just "good luck"?
Old 06-17-2015, 06:57 PM
M1A
M1A's Avatar
I have the same issue. One headlamp delays slightly when the lights are turned on and also when turned off. I searched the forum and also googled it. I never did find a fix. I thought the gears may be slipping in the light that delays but it sounds normal when operating.
Old 06-18-2015, 08:41 AM
shootnstarz
shootnstarz's Avatar
Check all your bolts and screws, make sure they're good and tight. Also observe the linkage as the motor runs. If the motor starts the same time as the other but the light is delayed in opening there may be slop in the linkage, new bushings would help.
There is no adjustment other than the opened and closed position for the door. Mainly just work the lights and observe what's happening. You may be able to see what's causing the delay.
Good luck
RH
Old 06-18-2015, 11:46 AM
tbirdsps
tbirdsps's Avatar
Mine are about 1 second off. Consider that the wires are longer to the right side so the electrons have to travel further.....
Old 06-18-2015, 03:19 PM
Went
Went's Avatar
I'll check all the linkage, etc. Given its all good...maybe I'll resort to a PWM speed control of some sort and dial it in that way. Maybe...
Thanks, Terry
To 1989 headlight open timing
Quick Reply: 1989 headlight open timing
