Recalls on early C4
If it's a "safety" recall that hasn't been accomplished it will still likely show in a request by the dealer. I doubt that if it shows NONE outstanding that they would be required to confirm when/if done. The GM response/action I would think could vary dramatically. In the past dealers (it's been said) have gone to great lengths to satisfy owners. It's the NEW GM"!!
What year is this C4? Do you suspect a particular that maybe hasn't been done?
You can find out what recalls have not been done here https://my.gm.com/recalls/?evar18=cca_recalls_btn
(This is for recalls issue after Aug 99)
Crossed Flags Fan (04-25-2016)
Outside of safety recalls which is required to be fixed for the life time of the vehicle that is still being used on public roads, I'm not a aware of any way to determine what recalls were applied to a car.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Years back they had safety recall on the seat belts, which if never done still active, problem is parts. In the past I have seen seat belts that doesn't match the interiors, cause those colors were available.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Engine harness connector inspection
Early C4s had a cheap wire insulation that would shrink back almost a full inch from the connector. Leaving the bare copper exposed to create shorts and fires. Inspect every engine bay connector for th
