window motor and switch problems
2nd Gear
In my 94 the windows stopped working. I replaced the drivers side switch and they started working again but once I hit the automatic down the motor tried to keep running down and it burned the switch out again. What is it that is supposed to kick the motor off once it hits the bottom and how do i adjust it
Not sure but might need a new motor.
Many GM cars have a circut breaker in the the fuse panel for power windows and you should be certain that if your car has a circut breaker for the window circuts that's it not temporarily "open"
dukes18 (05-27-2016)
