OBD 1 to OBD II connector
Old 12-04-2008, 11:51 PM
kjgcsmith
kjgcsmith's Avatar
Default OBD 1 to OBD II connector
Anyone know where I can purchase an 12 to 16 pin connector? I have a GM Tech 1 analyzer with the OBD II cable that I need to connect to my 95 vettes OBD 1 port.
thanks
Old 12-05-2008, 05:49 AM
jim_hewett
jim_hewett's Avatar
Default OBDll Connector source
ALDLCable.com 888-469-3274
Old 12-05-2008, 01:57 PM
toptechx6
toptechx6's Avatar
thanks
You will need to haunt E-bay until you get lucky, they do come up for sale on occasion, the adapter you need is P/N 3000053.
I use search terms GM Tech 1 and Vetronix as saved searches and get notifications when new items are listed, good luck.
Old 12-05-2008, 08:05 PM
kjgcsmith
kjgcsmith's Avatar
Jim, I checked out their site but they don't have an OBD2 to OBD1 connector or OBD2 to 15 pin (DB15F) which is the connector on the TECH 1.
AM I just missing the part on their website?????
Old 12-06-2008, 06:52 AM
jim_hewett
jim_hewett's Avatar
Will touch base w u when I run across one.
Old 12-06-2008, 05:20 PM
corvette95
corvette95's Avatar
to use it on your 95 you may have to have another box similar to a candi module for the tech 1 to work on the 95 and 96 cars. cant remember the name of it. (this is in addition to the obd 1 to 2 adapter)
Old 12-07-2008, 05:21 AM
toptechx6
toptechx6's Avatar
The VIM or Vehicle Interface Module you are thinking of is only required on 96 C4's, that is the only year that is OBDII, the 95 is OBDI but has the 16 pin ALDL identical to the OBDII connector, all the OP needs is the 12 to 16 pin adapter for his Tech 1 to work.
Old 12-07-2008, 10:12 AM
corvette95
corvette95's Avatar
yes..thats it. Are you sure its not needed on the 95 too? The 95 is also a hybrid obd. But again.... if you are sure.. I am not.
Old 12-08-2008, 09:43 PM
kjgcsmith
kjgcsmith's Avatar
Everything I have read leads me to agree with TopTechx6. I think the GM part number for the 12/16 pin adapter is 30000055 (or 53). Appreciate anyone letting me know if they come across one .... or the 1MB Mass Storage cartridge part number 3000003.
Old 12-09-2008, 05:53 AM
toptechx6
toptechx6's Avatar
There may be another adapter that will work,seems like Vetronix made a lot of them, but the one I have is the 30000053 number, pics below to help identify.
I do not know the function of the switch, sorry.
Old 12-09-2008, 11:55 PM
kjgcsmith
kjgcsmith's Avatar
TopTechx6.....is this for sale????
Old 12-10-2008, 06:21 AM
toptechx6
toptechx6's Avatar
Sorry no, but if you can't locate one and need to borrow it let me know.
Old 01-17-2009, 02:24 PM
yellowlust
yellowlust's Avatar
As the 95 is a ODB-II Port and is still OBD-I, what happens when you use an OBD-II interface + cable (such as and ELM 327-based) with OBD software?
Does it work?
Old 01-21-2009, 10:17 AM
pcolt94
pcolt94's Avatar
thanks
I have a 94 with the OBD2 connector also. A couple years ago I bought a Tech 1 but did not get the adaptor. I went on the Vetronix web site, found the piece and called Vetronix and ordered it. If I recall it was not cheap, about $70 and at that time there was a bit of a wait to receive it. (After spending a pile of money on the Tech1 how could I not buy the adaptor no matter what the cost.)
Have never seen one on Ebay, and only ever seen 1 adaptor included with a Tech 1 kit on Ebay in years.
I will see if I can find my original receipt and PM you any necessary information required to purchase it. Hopefully they will have some in stock.
Old 01-21-2009, 01:33 PM
toptechx6
toptechx6's Avatar
pccolt94 is correct that some items are still available from Vetronix, now a division of Bosch, that one seems to still be available. Here is a link that should help.
http://www.boschdiagnostics.com/part...3100parts.aspx
I have actually had pretty good luck finding adapters, etc on E-bay and the prices are usually way cheaper, I have had to buy some items as part of a "lot" containing others not needed, but still usually comes out less money. Let me know if anyone needs an Isuzu adapter!
Old 01-22-2009, 01:42 AM
VenkmanP
VenkmanP's Avatar
You guys know you're talking about two wires, right?
If you need to query stuff beyond PCM & CCM then you might need a couple more, not sure.
For a production environment the adapter makes sense, but for DIY use $80 is a lot for a couple of wires.
Old 01-22-2009, 07:47 AM
pcolt94
pcolt94's Avatar
Sure, rub it in, your basically right and know what your getting at electrically. It was a bit gut wrenching to fork them over the money for the adaptor but I wanted to get up an running soon as possible and wanted the correct piece for the Tech 1.
I’m in the electronics business and have built all the serial interface boards for use with a laptop PC. In that case I actually have installed an additional connector in the car connected to the ALDL using my own plus and design. I can just plug in the PC easy now. The problem I had was trying to find just the 12 or 16 pin connectors for my personal use. I did look around but could not find any connectors which is the reason I designed my own for the PC. And also the reason I bought the adaptor for the Tech 1.
To OBD 1 to OBD II connector
Old 02-28-2010, 01:30 PM
theother_bob
theother_bob's Avatar
I know this is an old thread, but I'm facing the same issue with my 95 Aurora. Would it be as simple as replacing the car's connector with an OBD1 connector from the salvage yard? Just match up the pinouts? TIA!
Old 03-02-2010, 12:31 PM
jimbo84
jimbo84's Avatar
Check napa, they sell the tech 2 made by bosch. They may be able to get the adapter
Old 03-04-2010, 06:38 PM
theother_bob
Thanks. For the time being I was able to make my own jumper which is working great for SDL (Engine and Body stuff) just not E&C (entertainment & comfort controls or something like that.) Eventually I'll get the adapter off ebay for the right price.
Quick Reply: OBD 1 to OBD II connector
