c4 ABS / ASR Service Light On
Hello guys! I am new to this forum and found out to be very informative. I am from the Philippines and has a garage for restoring vettes and stangs. I have an issue on the ABS / ASR Service Soon where lights come on but no unusual driving faults has been observed, so far.
its a 1992 C4 coupe, when lights turned on I check the brake fluid level but on the max level, cleaned all the sensors ( abs / front and rear, brake fluid level sensor ) still light comes on. Made a fast run and sudden brakes still light is on.
Has plug in an ALDL short connector and found a fault code on Module 9 which is H23 and H73? What does is mean?
Can anyone give me a start off on my quest? Thanks in advance guys for your help!
Best regards from the pacific......
