Problem ECM Hypertech Power Chip
Old 04-04-2016, 02:39 PM
ShadeTreeJW
Cruising
ShadeTreeJW's Avatar
Default Problem ECM Hypertech Power Chip
I own a 1990 Corvette, 6 speed, factory stock, except ....
Previous owner installed a Hypertech 150372 Power Chip. This is the Thermo Master chip.
The factory specifications say that L98 engines will rev up to 5500 rpm. This engine will not rev above 3500 rpm. At 3500 it stops flat, like there is a governor attached to the engine.
Any ideas ?
Thanks, JW
Old 04-05-2016, 03:37 PM
eutu1984
eutu1984's Avatar
2021 C4 of the Year - Modified Finalist
do you have the stock memcal, if so install it and see what happens, If you can data log that would help also. also are you sure your tach is accurate.
Old 04-06-2016, 08:47 AM
bjankuski
bjankuski's Avatar
Any ideas ?
Thanks, JW
Will it rev above 3500 RPM in park?
Old 04-06-2016, 03:36 PM
Kevova
Kevova's Avatar
If it still has a cat conv, it maybe restricted.
Old 04-07-2016, 12:45 AM
ShadeTreeJW
Cruising
The Corvette has a Hypertech Power Chip, Thermomaster, in it.
The 1990 Corvette has never revved over 3500 rpm, hits 3500 rpm and flattens out like it has a governor on it.
Today I removed the Hypertech chip and reinstalled the stock Corvette chip. In neutral, parked, the engine freely reves up to 5500 rpm. When I cursed around the block, 4500 rpm was easily obtained, on a busy residential street I did not want to jeopardize any traffic. I was able to obtain 4500 rpm several times, with some hesitation and surge, but I think this could be resolved with a tune-up.
It just goes to show you how worthless these performance chips really are, $200.00 ????
Thank you all for you input and advice. I would not have achieved my results without your information.
JW
Old 04-09-2016, 10:35 AM
84Z51J
84Z51J's Avatar
Not worthless to Hypertech--they have $200 of the P.O.'s moolah
To Problem ECM Hypertech Power Chip
Quick Reply: Problem ECM Hypertech Power Chip
