zz4 383?
zz4 383?
i have a zz4 engine needs a rebuild and was thinkin about making it a stroker. how hard is it to put a tpi or ltx setup on that engine even if i didnt make it a stroker? not sure if i would put it in the vette but it would be tempting.
The ZZ383 uses fastburn aluminum heads, so you will need the Scoggins-Dicky intake manifold to fit the TPI. Also your current smog equipment won't match up because of these heads either, but I think Scoggins Dicky makes some kind of adapters. But it should be a heck of an engine once installed and working. Let us know the trials and tribulations and...ahem...the 1/4 performance.
parts
right now that engine has got major blowby rings i guess what parts did you use is there any kits? should i change cams? while i want to do this i want to keep the cost down and use what i got but if its a worthwhile spend for something that should be upgraded im doin it
what parts did you use on your zz4 conversion? thanks for the input if you have any pic or sites that would be helpful postt em pleez
i was also worried on how hard it was to hook up the computer stuff for the tpi new chip i know but is it a pain dumb question
what crank and how much is the one in there worth
Oh and the stock 350 cast cranks makes a great doorstop or can be sold for scrap. At the machine shop I worked at, we'd just leave them out for the scrap metal guys, lol.
