cigarette lighter fuse
Old 04-23-2006, 03:37 PM
mothersworry
mothersworry's Avatar
Default cigarette lighter fuse
I have a 92 coupe. Whereis the cigarette lighter fuse? I cannot seem to find it in the passanger side fuse area.
Old 04-23-2006, 05:45 PM
mothersworry
Old 04-23-2006, 06:07 PM
darkred91
darkred91's Avatar
I have a 91 and it's under the dash on the passenger side.I stoped smoking...Good Luck..
Old 04-23-2006, 08:11 PM
Jerris
Jerris's Avatar
On the 92 the fuse is in the Auxiliary fuse box located under the dash after you remove the carpet knee hush panel.
The fuse is marked B CONV PL and the lighter is the only thing on it.
The fuse is fed through one of the fusable links located under the battery. If it is not the fuse, check the fusable link.
Old 04-23-2006, 11:25 PM
mothersworry
Jerris- I have looked under the driver side dash for the Auxiliary fuse box. Where is it located under the dash?
Old 04-24-2006, 08:46 AM
rick lambert
rick lambert's Avatar
Don't know-but keep this post going- love that avitar.
Old 04-24-2006, 11:46 AM
Jerris
Jerris's Avatar
Once you remove the carpet/plastic hush panel from under the dash the two aux fuse boxes just hang on wires under there. They may be tucked up behind other wires but they should be able to be pulled down as they have longer wires.
Old 05-14-2006, 02:42 PM
frannyzvette
frannyzvette's Avatar
Under the dash? not with the rest of the fuses right?
I want to install my Sirius, and the lighter is not working, (NOT A SMOKER!)
Old 05-14-2006, 02:57 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Didn't your mother tell you that smoking would stunt your growth? You don't need that thing anyway.
(I just carry my trusty Zippo)
Old 05-14-2006, 03:06 PM
darkred91
darkred91's Avatar
What I did to find it was take a mirror put it on the floor board it's up in there and it will pull down. Good Luck it's a wire nest take your time it's there...Passenger side............
Old 05-14-2006, 06:51 PM
frannyzvette
Thanks everyone! Now I have a usuable cigarette lighter (FOR MY SIRIUS!) AND workable power locks!!!!! Happy Mothers Day to me!!!
Old 03-21-2013, 08:58 PM
NCSU-C4
6th Gear
NCSU-C4's Avatar
Can anyone tell my where all the screws are to remove the panel? Apparently removing the two 7mm screws near the light aren't enough
Old 01-25-2015, 11:23 AM
girlwatcher1967
2nd Gear
girlwatcher1967's Avatar
Are you stating that replacing this single fuse ALSO fixed your power door locks as well? I read ealier that someone stated this fuse only powered the lighter.
Old 11-15-2020, 01:25 PM
Nick B.
1st Gear
Nick B.'s Avatar
Default Cigarette lighter
Hi All,
I have a 92 couple from the original non smoking owner with a cigarette lighter not working. I have power there and the element gets hot but, you have to hold it in for it to work. It won't stay in and pop out.The element looks brand new so, is it the element or the housing.
Thanks for any help
To cigarette lighter fuse
Quick Reply: cigarette lighter fuse
