pcmforless recomends comp467 for lt4
Old 05-04-2006, 10:43 PM
dominr8
dominr8's Avatar
Default pcmforless recomends comp467 for lt4
i talked to pcmforless about an upcoming header,cam and head swap and they said the comp cam 467 was an excellent choice for a modified lt4. said it had a fair idle and would really haul the mail. \
comp cam xfi lt1- 230/236
576/570
lsa/113
does anyone have this cam
Old 05-05-2006, 02:12 PM
Vette Threat
Vette Threat's Avatar
Old 05-05-2006, 03:08 PM
ScaryFast
ScaryFast's Avatar
576/570
lsa/113
Mine's a very similar custom grind (CompCam (0.577/0.573, 230/236 duration, 112 LSA +2*)), I'd agree with the assessment. The overlap is the same as the 467, I couldn't believe how smoothly it idled.
I only got to run it at the track twice before I broke the bottom end, so I can tell you a little about how well it performed; quite well.
Old 05-05-2006, 04:57 PM
vettef6
vettef6's Avatar
I'm very satisfied with my cam, see sig., which is also very similar to the 467. Engine idles at about 900 rpm and really moves past 4000 rpm all the way up until I shift at about 6300-6400.
Arnold
Old 05-05-2006, 06:56 PM
TM-Z06
TM-Z06's Avatar
What kind of power are you guys putting down with that heads/cam combo? Track times??
Old 05-05-2006, 07:51 PM
Vette Threat
Arnold
Is that a custom grind?
I'm looking for a cam with those specs as well.
Old 05-06-2006, 09:45 AM
aboatguy
aboatguy's Avatar
I believe your talking about the 280 XFI here's the blurb from CC
"XFI" 280 Hydraulic Roller Camshaft
GM LT1 & LT4 350ci 1993-96
Lift: .576"/.570" w/1.6 Rockers
Duration: 280°/288°
RPM Range: 2000-6000
Duration Advertised: 280° Intake / 288° Exhaust
Duration @ .050'' Lift: 230° Intake / 236° Exhaust
Valve Lift w/1.6 Rockers: .576'' Intake / .570'' Exhaust
Lobe Separation Angle: 113°
"Strong mid-range and top end. Will require headers gears & stall speed. Strong idle."
CC states it has a strong idle. If PCM for Less recomended it I'd trust their judgement and follow their recommendations.
Mike
Old 05-06-2006, 12:57 PM
vettef6
vettef6's Avatar
Serial # Z 5055
Part # 07-000-9
Grind: LT1 3111S/3122S HR 114
Gross valve Lift: .565"/.603"//.570"/.608"
Duration 286°/290°
Lobe Lift: .3770"/.3800"
Lobe separation 114°
Small base circle cam
Arnold
Old 05-07-2006, 10:59 PM
Vette Threat
Serial # Z 5055
Part # 07-000-9
Duration 286°/290°
Arnold
So thats 603" 608" with 1.6 rockers or 1.7rockers?
Old 05-08-2006, 05:41 AM
vettef6
vettef6's Avatar
It's just what is says in my sig. 1.6 RR
Arnold
To pcmforless recomends comp467 for lt4
Quick Reply: pcmforless recomends comp467 for lt4
