Pump Gas 427 flow chart
Better than expected flow numbers. Heads were built for a real street engine running 10.0 to 1 compression and a streetable cam. Amazing work from one of the best porters in the country. The flow chart was done in MD when the heads were returned to confirm the flow numbers.
The heads are a rare set of untouched (before I got them) PRO raised runner heads. One of, if not the best SBC heads ever made short of the Nascar stuff.
Cruise-In VII Veteran
Without saving that photo and blowing it up I couldn't make out the numbers.
I take it the heads were flowed at 25" and then the numbers corrected to 28" ?
Pretty damn impressive all across the board. What are the spec's - valve sizes, minimum CSA, runner volume ?
So you are going to have a blown ZL1 with 355cfm heads in your 90 C4? JHC! Think you'll have enough power?
Are you going to have a cam with .7 lift to get the max from the heads, because I thought you couldn't go with a real big cam on a blown car?
How much rwhp are you expecting?
Is the going to be a street car or a "Real Street" class drag car?
The cam has not been ordered so I don't know the specs. I would guess it will be in the mid to high 600 range based on the flow chart.
