antenna hook up
Old May 11, 2006 | 03:51 PM
Medicman55's Avatar
Medicman55
Default antenna hook up
Hey everyone,
I just bought my new mast and i am ready to install it. The only problem is that I dont know where to feed the metal end to. Where does it hook into?
Medic
Old May 13, 2006 | 04:23 AM
86PACER's Avatar
86PACER
What year Vette?
On the early antennas, inside there is a recess cut out on the drive gear for the hook end to hook to. Then the rest of the mast is wound around it. Here's an illustration.
Old May 13, 2006 | 05:12 AM
slicked25's Avatar
slicked25
You stick the gear down the antenna hole of the car while turning the radio on and off and eventiually it will grab. Mine still get's stuck every now and then but after applying paint thinner is works great.
Old May 13, 2006 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
That only works on the newer style. 86Pacer's drawing shows the style antenna motor you have. Here's a little more info on the subject.
http://members.shaw.ca/agent86/Power%20Antenna.pdf
To antenna hook up
