High Idle
Old May 12, 2006 | 02:06 PM
c2c4c6's Avatar
c2c4c6
Default High Idle
I have a 1992 LT1 and the idle is too high (it is a 6 spd). As I slow down and punch the clutch the idle is at 1300. Once the car is fully stopped the idle slowly settles down to about 900. The idle is also at about 1300 cold. Any hints as to what I should look for?
Old May 12, 2006 | 02:13 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check all your hoses and your intake coupler for holes i.e. vacuum leaks first. Then remove the TB from the plenum and clean it and the idle air controller (IAC) motor.
Read the TB removal/cleaning article in the C4 tech tips section on this Forum on how to do this. Should correct your problem. It did on mine.
Old May 12, 2006 | 11:12 PM
c2c4c6's Avatar
c2c4c6
What is the intake coupler?
Also, I can't find the tech tips section of this forum - where is that.
Thank you for your help. I'll try what you have said.
Old May 13, 2006 | 01:55 AM
jabez's Avatar
jabez
Its between your TB and your air filter housing.
Its connected to TB and looks like a hard plastic tube.
Old May 13, 2006 | 08:18 AM
RRT vette's Avatar
RRT vette
https://www.corvetteforum.com/techti...=195&TopicID=2
And maybe this too. From Vader86 webpage.
http://temp.corvetteforum.net/c4/vader86/tpsiac.html
Old May 13, 2006 | 08:54 AM
c2c4c6's Avatar
c2c4c6
Thanks.
To High Idle
