Can you lubricate ignition lock cylinder?
Old 09-04-2001, 05:43 AM
jackdaroofer
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Can you lubricate ignition lock cylinder?
Just read archived C3 post about lubricating by putting Mobil 1 on key.
Doesn't seem like that would be good for VATS.
Jack
Old 09-04-2001, 06:16 AM
JasonL
JasonL's Avatar
Default Re: Can you lubricate ignition lock cylinder? (jackdaroofer)
Yikes. The common (correct) way to lubricate locks is with dry graphite lubricant...or powdered pencil lead, basically the same thing :D It did wonders to my locking gas cap which was getting reeeaaalll sticky. I don't know if it will interfere with VATS but I doubt it.
Old 09-04-2001, 06:21 PM
Mez
Mez's Avatar
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Can you lubricate ignition lock cylinder? (JasonL)
You can buy graphite powder mixed with mineral spirits. Once its in the lock, the mineral spirits evaporates leaving just the graphite. A lot easier to get in the lock than powdered graphite. It may be named Lock-Ez or something similar. Works great. I think you need to stay away from oil as they turn gummy after a few years.
Old 09-04-2001, 09:45 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Can you lubricate ignition lock cylinder? (Mez)
Will graphite screw up VATS sensors?
To Can you lubricate ignition lock cylinder?
Quick Reply: Can you lubricate ignition lock cylinder?
