Key warning buzzer
Key warning buzzer
I hear the faint sound of a dying warning buzzer, but i cant find the buzzer. Its so low you almost have to hold your breath to hear it but its somplace under the dash. I droped the Driver side dash panel, but all I see is connectors. As I remember on my other cars it was a little box that pluged into the fuse box. Am I looking in the right place?
Not sure if this relates to your issue but my 93 was buzzing and I couldn't get it to stop. I searched on this site and found a tip on checking the interior lighting fuses. I hadn't even noticed that my door panel lights were not on. Sure enough that was my problem. Good luck.
The warning chime is supposed to be center of I/P, in multi-use center.
http://members.shaw.ca/agent86/CHIME.pdf
