Hood stuck shut
Old 04-03-2007, 11:42 PM
JAKE
JAKE's Avatar
I've had several occasions when the hood on my 86 wouldn't open with the under dash light. Each time I was able to open it by using only a coat hangar fished under the hood.
Sure it took some time and some patience, but it worked each time.
Jake
Old 04-04-2007, 05:50 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
Originally Posted by laughac
I'm sure it was all good advice, but I am only home for a matter of hours each weekend. After spending time with my kids I sneak out an drive my Porsche for an hour or so, which has left me only a few minutes to try getting the vette hood open each weekend.
I 'made' the tool suggested, using a dent king tool I had, but never could get enough leverage on the passenger latch. Time is money, so I've had to opt to pay GM techs for their time on this issue.
Thanks very much, all. I'll surely need your help again sometime after the hood opens.
I understand, good decision.
Old 04-04-2007, 05:53 AM
runner140*
runner140*'s Avatar
Originally Posted by kiwi1
For the future - Corvette Fever TechTip: tie 3' nylon
twine to each release (what the cable moves) and
tuck it within reach near wipers for opening if new
cable ever breaks again. If the twine is white, blacken
it with shoe polish so it's not obvious to vandals.
Rather then use nylon twine, use 18" black zip ties. I change mine about once a year because of the heat.
Old 04-04-2007, 08:46 AM
ogres84
ogres84's Avatar
This is one of the best remedies I've seen so far for the dreaded stuck hood problem:
http://forums.corvetteforum.com/show....php?t=1657961
Old 04-11-2007, 11:06 PM
nitecruizer
nitecruizer's Avatar
YOU DRIVE YOUR PORCHE FOR AN HOUR WHEN YOU CAN SNEAK OUT, WHATS WRONG WITH YOU, I WOULD RATHER DRIVE A VETTE THAN A FREAKIN PORCHE OR POOCH OR WHATEVER.
89corvettemann (09-04-2023)
Old 04-12-2007, 01:58 PM
GIJoe
GIJoe's Avatar
St. Jude Donor '08-'09
I have never lifted the car since hearing it could crack yjr roof. When it gets warmer I'll find more time.
Thanks!
It's a good thing the roof comes off
Whenever I lift mine, I crack open both doors, pop the hatch so its just barely opened (free from the body) and loosen all the roof bolts and pick it up and set it back down to make sure its not stuck... once its all loose, then I jack it up. Since the car is a unibody with fiberglass everything ,the entire car flexes, which can cause the roof and other parts to stress, then crack after a while.
Old 04-13-2007, 03:05 AM
rodj
rodj's Avatar
"Since the car is a unibody with fiberglass everything"
The C4 actually has a complete steel frame with the f/glass bonded to it.
The steel beams also run across the rollbar/ firewall making it stronger than a true unibody setup where all the strenght is in pressed metal profiles
On both my C4's, I can jack both wheels on one side off the ground from the rear jack point and still open-close doors / hood freely while suspended .
Old 04-13-2007, 05:28 PM
JAKE
JAKE's Avatar
I agree. I've jacked up both of mine so many times I can't recall the count. I've never opened the doors and/or hatch either. Never had a single problem.
In fact I purposedly kept the doors closed so I could listen to the cars' radio while I was underneath, without that annoying ding, ding, ding.
If it's in the FSM, that they should be opened, I missed it. Clue me in.
Jake
Old 04-14-2007, 01:03 AM
MDred85
MDred85's Avatar
Hello,
My 85 needs me to activate the hood release and at the same time lift up on the hood. Hope it works for you.
MDred85
Old 04-19-2007, 09:26 PM
laughac
laughac's Avatar
Default Nearly $500 to fix
Dealer installed new hood latch cables, hardware, and release handle. $45 of the labor cost was for getting the hood open.
$210 in parts... the rest of the cost I chalk up to not having time to do this work myself.
Thanks for all the info. Now that the car is back home I need to add the tie straps you guys recommended.
toddbvanslyke (08-27-2018)
Old 04-19-2007, 10:15 PM
Slalom4me
Slalom4me's Avatar
Sometimes this is how jobs play out.
No matter, glad to hear that the hood release is operational again.
Old 04-21-2007, 09:32 AM
STREETKNIGHT
STREETKNIGHT's Avatar
St. Jude Donor '03-'04-'05-'06-'07
I'm with you on the time is money routine. Pretty much what I do now on the wife and kids cars and my DD. I pay someone who does this for a living and I go out and do what I do best to earn the $$ to pay for it
But now, since the vettes just a toy, I'll wait until I can find the time to try to do it myself.
BTW, no sense in paying $40.00 (+/-) for the tool
Hecklers has it as does Davies Corvette Parts and Supplies in Florida. It's $19.95 at Davies and they have it in stock. Actually $.04 cheaper than Hecklers (not to mention having to deal with Hecklers )
Just picked mine up yesterday. Gonna go get some Ice tea and a chair and start playing with it until it opens
Old 04-21-2007, 08:50 PM
  #33
laughac
laughac's Avatar
LOL! Let us know when you get it open.
Old 03-02-2009, 07:35 PM
  #34
green 91 vette
1st Gear
green 91 vette's Avatar
Default Worked for me
This was very helpful and worked for me to open the hood of my 91 vette. Thank you to all who posted. Thought I would add a little more.
I made a tool out of a shelf bracket with 1/4 inch steel tube. The tool I made was 18 inches long, but I'd suggest you make one a little longer. The bend on the end should be less than 2 inches. I tried for 10 minutes without success, then I bent the tool inward about 6 inches from the end, then it worked. The end was round when I used it. Afterward I sharpened it on a grinder like a large flat head screwdriver for these pictures, because it will be easier for you.
Tool side view
Tool above view
Tool tip
Latch in resting position
Latch when you open it.
View from above. The latch you are trying to reach is exactly 13 inches from the corner of the windshield molding.
Good luck!
Last edited by green 91 vette; 03-02-2009 at 07:48 PM. Reason: added info to pictures
Old 03-02-2009, 09:25 PM
  #35
tonylong
tonylong's Avatar
Originally Posted by 80sRule
You've been given good advice, and I hope I can offer something.
The former owner of my car installed zip ties on the hood releases so if the hood cable crapped out, you could get access to them with nothing more than pliers. I'd install some of them once you get your new cable installed.
Good Luck,
80sRule
This is a great idea! I could've used it yesterday. I did finally manage to get it open using the "Killebrew" tool. Can you post close up pics of the zip ties? That sounds way easier. Thanks
Old 03-04-2009, 10:12 AM
  #36
Da Mail Man
Da Mail Man's Avatar
...see post 5 and following associated posts to get you in in the future...
http://forums.corvetteforum.com/c4-t...-not-open.html
Old 05-31-2017, 03:55 AM
  #37
Cliff Harris
Cliff Harris's Avatar
Originally Posted by Kool88vette
Mid America has revised their site. Try this link:
http://www.mamotorworks.com/Corvette...-tool-609637-1
To Hood stuck shut
Old 05-31-2017, 02:38 PM
  #38
billschroeder5842
Zen Vet Master Level VII
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
I did the same but with thin cable wire. They both work the same. Totally worth the piece of mind.
You can get kits on Ebay for $25. Takes about 15 minutes to install.
Old 08-25-2017, 07:44 AM
  #39
xc3
7th Gear
xc3's Avatar
Yes. I had this problem with my 88. I put the front up on jackstands and removed both wheels. There is a plastic cover held on by 4 bolts in the wheel well. Remove the covers and you have access to the engine compartment. I heated up an old screwdriver and bent it into a hook. I reached up inside and released the hoodlatch on both sides. Then I changed the cable.
Thank you, Thank you
Old 08-27-2018, 12:20 AM
  #40
Leonardo111
5th Gear
Leonardo111's Avatar
Here's a vid i made on diagnosis:
And how to make nice E-release cables:
Quick Reply: Hood stuck shut
