suspension upgrades?
I have C4 suspension on my car
http://www.lateral-g.net/sidelnyk/
are there basic and proven upgrades you recommend...?
Sweet car.... Lots of things you can do. Looks like you already have coil overs in the front. Consider matching in the rear.
Check Dougrippie.com I'm using some parts from them, coil overs, cut rear knuckles, relocated camber & 4 link points & solid/heim jointed sway bar ends.
Then guldstrand.com or vettebrakes.com for heim joint rear toe & camber rods.
Sway bars you can get anywhere.
Correction you can get sway bars. Going to be my first suspension upgrade...
http://www.vbandp.com/SearchResult.aspx?CategoryID=6
Semper Fi
