Mobil 1 in my new engine?
I completly rebuilt my 350 about 6 months ago and have since put only 1500 miles on it. I just changed the oil the other day and used Mobil-1 synthetic for the first time. I have read posts on here that synthetic is no good...especially with a fresh engine. Do you guys think I should change out the synthetic for a conventional oil?
-Thanks
-Thanks
Received 3,043 Likes
St. Jude Donor '05
d leave it in and continue to run it. Im going 500 miles on my new one and then switching from Dino to synthetic.
I second the keeping it in. It wont do any harm to the engine and 1500 miles it should be pretty broken in anyways. Most new performance engines are broken in on the stand for less than that number of 'miles' and then filled with Synth and stuffed into the cars.
Received 1,407 Likes
The L98 did not require Synthetic because it had an oil cooler. When the LT1 went into production GM had found out that by using Synthetic they could maintain the oil temp without an oil cooler. Generally speaking an LT1 engine will run 30 to 50 degrees hotter without Synthetic oil.
Location: One day you're a Comet...the next day you're dust... Arkansas
