What does the brake bias spring upgrade do?
I assume the brake bias spring upgrade, such as the one offered by DRM, changes the ratio of pressure applied to the front vs. rear brakes. What is it doing, exactly? More of a braking bias toward the front? More toward the rear? And how does this improve stopping distances?
I have searched on this to no avail. Any info appreciated.
David
David
David
David
Semper
It puts more to the rear. You didn't find any info? There have been a bunch of threads, there was a HUGE one a while back with very detailed info.
Braking into a corner would be trail braking, an advanced skill, with incorrect modulation you can have snap overseer and spin into a wall. The bias spring will help with nose dive, but so will a stronger front spring. A lot of people brake before the corner, let the car settle, then turn in.
The install wasn't to bad at all. I just finished it up two weeks ago. It took many tries to get that clip back in. Tearing it all down was very quick. The C5 calipers are huge compared to the small stockers.
bias spring
the purpose of the bias spring is to change the pressures to the rear brakes. The initial brake application has the same pressures front and rear. the spring changes the rear pressure by moving a internal second smaller piston at a predetermined cracking pressure. at the cracking pressure the two pistons work together to control the pressure bias.
St. Jude '03-'04-'05-'06-'07
Just a note on searches, include archives, and do a search in each c4 section for best results...Just did a search and found 4 pages of bias spring posts.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Pretty much it. It leaves the rear brakes at full pressure for longer before finally reaching the crack point where rear pressure increases at a lesser rate than the fronts.
GM underbiases the rear brakes for safety/liability reasons. There is quite a bit of room for improvement, especially on a car with such a low center of gravity and good weight distribution. I believe GM continually increased the rear bias through the C4 run as if they gained more confidence in their engineers. I haven't verified this yet though.
With all the bias springs being installed and some of the stories of parts flying around, I have decided to document this information of my procedure.
Hear is how I did it;
- Follow DRM instructions. This is additional info to get the spring in the valve
- Remove master from car and end nut that holds valve in and small tapered spring.
- Strike master on end to remove valve from master, (use wood). Remove O-ring and metal spacer.
- Record all configurations of parts removed.
- Take a 19mm deep socket and place in vice vertically.
- Wrap the valve in a paper towel to protect it and slip into socket so C clip is up.
- Take snap ring pliers and remove C-clip and spring.
- Drop new spring in valve.
- Get a straight blade screwdriver wide enough to depress spring into valve.
- Place C-clip thru screwdriver and grab clip with snap ring pliers and place screwdriver onto spring.
- Press spring with screwdriver down into cylinder, lower C-clip with pliers and snap in.
If you mess up, you wont loose the C clip. Getting it in the first time is easy.
- lube piston valve and re-assemble master in proper order.
- Bench bleed master and install back in car.
- Bleed master at fittings and or system.
Best of luck
Spring in valve and valve in socket.
Ready to push spring into valve
Spring pressed in valve and ready to drop C-clip in.
Okay, so now I understand what it does and why this helps in the twisties. Thanks!
So which would stop in the overall shortest distance, stock spring or upgraded spring?
Also, is the spring more/less/same desirable with the C5 front brakes upgrade as with stock C4 front brakes? (I guess what I'm wondering here is if it wouldn't be better to have more bias to the front when you have upgraded to to a beefer front setup.)
I'm considering the C5 upgrade in front and am trying to decide whether the bias spring should be part of my mod.
Thanks for all the info guys. (and the search tips)
David
David
The upgraded spring stops better and is more important to put in when going to the C5 calipers. I just picked up a set new, PM me if you need a set, he might have more.
On the contrary, when you upgrade the front brakes, you need to counter it by giving the rears more bias. This is because the new fronts with larger/more pistons and bigger rotors is doing more work with the same amount of brake pressure, so they'll lock up or engage ABS prematurely.
I don't see all the trouble with installing the spring. I had no issue with mine. It's stiffer, but shorter, so the preload is the same as the stock spring.
