Clicking noise
Old 05-13-2007, 08:39 PM
Repzard
Repzard's Avatar
Default Clicking noise
Hello All
It just started today, When I apply my brakes after going about 30-40mph I hear a clicking noise" CLICK CLICK CLICK" sometime which sounds like its coming from drivers side rear brake and when i apply my brakes just sitting still I hear the front drivers side making a sqeaky type noise.
But the brakes are stopping the car fine.
But the clicking noise is really bugging me.
Anyone know what these noise may be??
Old 05-14-2007, 10:37 PM
roy Arrington
roy Arrington's Avatar
I hope someone chimes in. My 89 has the same symptoms. A rotational sound around 20-40 that goes away with slight brake pressure but returns when the brakes are off. I'm concerned that it might be the half shaft u joints which were tight when I checked earlier in the spring BUT they are old and might be getting ready to go. I have a trip planned this weekend so I might just have the joints changed. The brakes were new last summer including all new rotors and pads. I'll let you know what I find on the u joints.
Old 05-14-2007, 10:53 PM
quiksilver458
quiksilver458's Avatar
U joints could be the culprit. Brake squeal could be the squeaking. I normally put the rear of my car up on stands and rotate the wheels by hand. I can normally tell which side the clicking is coming from by this method. I however must advise that if your removing one half shaft to replace u-joints, might as well spend a few more bucks and replace the others. They often fail not far apart, and its no fun going back up in there a month or two later.
Old 05-15-2007, 01:02 AM
94ZR1
94ZR1's Avatar
St. Jude Donor '06
There is also a spindle washer on the inside of the bearing assy that could cause this Clicking noise
Do a search using "rear clicking" or click with the archived threads enabled and you will find volumes of info
Usually its the washer and when its not its the u-joint
Old 05-15-2007, 01:08 AM
vinnies87
vinnies87's Avatar
St. Jude '03-'04-'05-'06-'07
Use the Search function, Advanced, include Archives and search, great tool to use, rather than wait for no response... If its a problem its probably already been listed and fixed...
Old 05-15-2007, 06:50 PM
CMYC4
CMYC4's Avatar
My 1991 does the same darn thing! and I don't have a clue what it is! hope some one does.....
Old 05-15-2007, 07:20 PM
JOESROAD
JOESROAD's Avatar
I would bet u-joints at the half shaft, my 88 coupe had the same issue and after they were replaced all is good.
Old 05-15-2007, 10:20 PM
RedCorvette1988
Support Corvetteforum!
RedCorvette1988's Avatar
I had a clicking sound. But the car rode smooth no vibrateing at all. I wondered about the U Joints -- I replaced them-- when I did I was shocked the inside joint next to the rear end Half shalf didnt have any bearing left and the cap was breaking apart. If you replace the U-joints on the half shafts remember to mark the cam for the alinement for the rear tires.
Old 05-16-2007, 10:39 AM
bd2626
bd2626's Avatar
Sounds about like mine did, u-joint on the half shaft
Old 05-16-2007, 05:48 PM
Repzard
Repzard's Avatar
All the U-joints and bearings are good they have been checked.
Its something to do with the brakes in the back.
So the car is at the place I bought it and they are replacing the rear brakes.
And im also getting the car tuned up" plugs and wires" and having new tires put on it as well all covered under warranty thank god!!!
One thing I was wondering does the OPTI have a cap like the HEI do??
But thanks for all the replies
Old 05-16-2007, 06:13 PM
Rex Ruby
Rex Ruby's Avatar
Philly 'Burbs Events Coordinator
Yes the Opti does have a replaceable cap.
Old 05-16-2007, 06:49 PM
Repzard
Repzard's Avatar
Ok thought so
To Clicking noise
Quick Reply: Clicking noise
