low rpm stumble
low rpm stumble
help ! i have an erratic idle , and a stumble/miss at low rpm's . so far i have changed the fuel pump , plugs , wires , cleaned the mass air , and throttle body . i have no engine smoke . 1986 l98 auto
Received 1,401 Likes
Re: low rpm stumble (markmaz)
I tend to have a surging idle in my 86 when it gets up to temp and sits for a little while. Did you replace the distributor cap? also try cleaning the IAC valve.
you should be able to clean it with Carb Cleaner or something like that, i would run a search on IAC cleaning before going ahead with it
if the idle air control is clogged up then it will cause the computer to have a fit and screw up your idle
