What is a good cam for 383/TPI?
Old 11-12-2001, 04:20 PM
dtorc4
dtorc4's Avatar
Default What is a good cam for 383/TPI?
What cam specs would work well for a daily driver 383 using stock 85 TPI (until I get LPE intake/base)? I would be using 24 lb injectors, no NOS or supercharger. Thanks. :cheers:
Old 11-12-2001, 08:07 PM
mountainmotor
mountainmotor's Avatar
Default Re: What is a good cam for 383/TPI? (dtorc4)
Are you using the 1985 block? What are is your rear gear ratio?Are planning on changing the gears? Headers?From what i read here you want a cam to get you buy until major changes are made.I would use this Howard cam in that block.It is a small base circle 215/225@0.50 440-465 lift 112 lsa .It is 100 bucks through Competition Products.That is if you only need a cam to get by with for a while.If not there are many choices
[Modified by mountainmotor, 6:16 PM 11/12/2001]
Quick Reply: What is a good cam for 383/TPI?
