How well does your car blow?
Old 11-04-2007, 02:05 PM
Danspeed1
Danspeed1's Avatar
Default How well does your car blow?
Hello,
Been tracking down this HVAC problem for a year now intermittently. Someone this week posted a thread about their heat giving them problems so I decided to start working on my system again. I managed (how I don't even know) to get the system to finally switch where the air blows out of (ex. defrost, vents). What I am noticing though is that even though the air is being directed out of the defroster for example, on 10 it is still not blowing particularly hard.
This is a hard question to ask because unless you are in my car it would be hard for you to determine if my air is blowing hard enough, but generally, do they blow pretty well or can you just feel some heat rising out of the vent even though the heat is on full blast? Is their some sort of filter in the system somewhere that could be clogged or something?
Finally, and this drives me particularly nuts in the summer. Even when the system is off, and I keep the interior temp at the lowest setting(60*F), the floor vents still blow a good amount of hot air at about 75MPH. Do all the vettes blow air?
Dan
Old 11-05-2007, 09:58 AM
Danspeed1
Danspeed1's Avatar
ttt
Old 11-05-2007, 10:11 AM
Aardwolf
Aardwolf's Avatar
After I cleaned my evap core there was plenty of air.
Old 11-05-2007, 10:48 AM
jsup
jsup's Avatar
Location: Bergen County, NJ Democrats, doing for the country what they did for Michigan
That's nasty.
Old 11-05-2007, 04:37 PM
Danspeed1
Danspeed1's Avatar
Originally Posted by jsup
That's nasty.
Is there anyway I can take a look at the evap core without having to rip the whole dash out... (sorry if this is a stupid question, the car is not around right now for me to run out and take a look)
Were you actually able to "clean" that or did you just replace it?
DG
Old 11-05-2007, 05:34 PM
Aardwolf
Aardwolf's Avatar
DG
I cleaned it, if you search on my name and evap you should find my old topic on it. I just took out the blower motor and used a camera to look at the evap core. The whole operation was not hard nor did it take long. Here is a picture after cleaning it:
A plugged core could be your trouble but there are other causes to.
Old 11-05-2007, 08:12 PM
ramiles
ramiles's Avatar
Curious - what makes that gunk and what are the factors that cause it to build up - is it simply the environment where you live (NJ?) - is there a way to filter the air to avoid that build up?
Old 11-06-2007, 07:35 PM
badabing9
badabing9's Avatar
could have been a refrigerant leak sometime in the history of the car as refrigerant contains oil.
To How well does your car blow?
Quick Reply: How well does your car blow?
