Vacuum Diagram 86 ???
12-04-2007, 01:01 PM
Hi All,
I can't seem to find a vacuum diagram in the FSM or the Haynes manual. I found it on the autozone web site but it was not clear at all and didn't enlarge or sharpen well at all.
So, does anyone know where thje vacuum routing diagram exists in the FSM and or even online?
Engine still shaking and running on 7 cylinders after hitting a pothole and I need to elimintae vacuum leaks.
Lee
12-04-2007, 01:15 PM
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Does this help?
12-04-2007, 09:41 PM
wOw!!! Thank you soooo much Ray!. Perfectly clear diagram and very much appreciated :-)
12-05-2007, 01:17 PM
Cruise-In I Veteran
Quote:
Originally Posted by
leefarah
No problem Lee, glad that's what you needed.
12-05-2007, 05:08 PM
Where abouts is the "tank pressure control valve" located, I cannot see it in my 87
12-05-2007, 08:25 PM
Ray Quayle
Does this help?
I believe that drawing is from a newer L98. On my 86, canister vacuum is from intake base port (shared with PCV), no TB connections.
12-05-2007, 10:27 PM
12-06-2007, 02:02 AM
Cruise-In I Veteran
AGENT 86
Dan, you're right, I posted the wrong diagram.:o I guess old age is catching up to me.
12-06-2007, 08:30 AM
Ray Quayle
We are only human, Ray
I have never seen the correct vac diagram, posted for 86, nor do I have one in my FSM.
Here it is doctored up.
12-06-2007, 08:31 AM
convas
Beside the charcoal canister
12-06-2007, 09:36 PM
Thanks Agent 86, looks like it is missing from my car.
12-10-2007, 01:51 PM
Cruise-In I Veteran
AGENT 86
Felt so bad about posting the wrong diagram, here is the one for the '86:
Much the same as Dr. Dan's, but now he can say he's seen the correct vac diagram for the 86 posted.
12-10-2007, 03:19 PM
Thanks Ray, I saved the pic
Where is the diagram from ??
12-11-2007, 01:25 PM
Cruise-In I Veteran
AGENT 86
Dan, Just took a pic of the label on the Radiator shroud.
12-11-2007, 03:13 PM
Ray Quayle
I was thinking about doing the same.
1987 ,
86 ,
87 ,
a1987 ,
c4 ,
corvette ,
diagram ,
diagrams ,
emission ,
info ,
line ,
pcv ,
system ,
tech ,
vaccuum ,
vacuum
