Which wiper blades fit.
Old 12-21-2001, 12:08 PM
C4 4Me
C4 4Me's Avatar
Cruise-In II Veteran
Default Which wiper blades fit.
Bought some brand at the parts store and they don't clear the hood. Which ones work and does anyone have part numbers? I hope I don't need to go to the dealer for wiper blades.
Old 12-21-2001, 01:13 PM
bogus
bogus's Avatar
Default Re: Which wiper blades fit. (C4 4Me)
go to the dealer... infact, if you call carfan18, Jeff Kopp, 1-800-728-8267, he can fix you up cheap.
I have found though tons of bad experiences, that factory wipers and incerts simply work the best.
I upgraded my wiper arms to 1996 spec... they seem to work much better! stiffer spring, beefier arms... well worth the effort!
Old 12-21-2001, 01:26 PM
92TripleBlack
92TripleBlack's Avatar
Default Re: Which wiper blades fit. (bogus)
Got mine from Jeff.
Old 12-21-2001, 01:55 PM
Goody
Goody's Avatar
Default Re: Which wiper blades fit. (92TripleBlack)
Apply a couple coats of rainX and keep speed about 80mph during rainy days. :D
[Modified by Goody, 12:02 PM 12/21/2001]
Old 12-21-2001, 02:10 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Try this trick first before replacing blades. Wet a scotchbrite pad with soapy water and clean the leading edge of the wiper blade to remove the old, hardened, oxidized rubber. The wiper blades should work like new.
Old 12-21-2001, 02:49 PM
Crazy Canuck
Crazy Canuck's Avatar
There is an aftermarket OEM replacement available from Triton. I don't have the part number, but they are an exact fit replacement for the Vettes.
Old 12-21-2001, 03:48 PM
Mez
Mez's Avatar
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Which wiper blades fit. (Crazy Canuck)
I second the Triton (or is it Tricor?). They are an exact match for OEM including the molded in notch end. I got mine at Wal Mart. I recall it was the model "B".
Old 12-21-2001, 03:54 PM
C4 4Me
C4 4Me's Avatar
Default Re: Which wiper blades fit. (Mez)
I will look for these, thanks.
Old 12-21-2001, 06:19 PM
Hawaii89vette
Hawaii89vette's Avatar
I bought some blades called "Exact Fit" .. I think from Trico. They fit great.
-Tim
Old 12-21-2001, 06:25 PM
PeteL
PeteL's Avatar
Location: And on the fifth day, subpoenas were served to Obama senior staff
I tried all of the aftermarket and then went GM. MUCH better. They actually work now. I either bought them from Jeff Koop or TLD, don't remember which but what a difference.
I know one of the big houses must make these for GM, but dang if I could find out which one. Been good now for a year, aftermarket either did not fit or were shot in a few uses.
Old 12-21-2001, 06:48 PM
ROADAPPLE
ROADAPPLE's Avatar
What's good for the General is good for the USA. If you buy aftermarket it's trial and error. The Generals' fit and work perfict. Sometime Walmart is not your friend.
Old 12-21-2001, 08:10 PM
JasonL
JasonL's Avatar
Default Re: Which wiper blades fit. (C44ever)
The problem is that GM blades are $25 each from a dealer. Jeff Kopp is probably less, but when you get caught in a rain storm, you get caught in a rain storm...
Old 12-21-2001, 08:20 PM
PeteL
PeteL's Avatar
Default Re: Which wiper blades fit. (JasonL)
I paid less then that for GM arms and GM wipers. You got to use your sources!
Old 12-21-2001, 08:26 PM
JasonL
JasonL's Avatar
Default Re: Which wiper blades fit. (PeteL)
Well, like I said! The rain storm waits for no one, not even the UPS man :D
Sometimes you don't have the luxury of waiting a few days for parts (daily driver)
Edit: The GM blades do work well, though. Brother even asked me if I recently put new wipers on...and mine are 1-yr old already.
[Modified by JasonL, 4:40 PM 12/21/2001]
Old 12-21-2001, 08:30 PM
PeteL
PeteL's Avatar
Jason, agree. But that's why you ask on the forum. It's worth waiting for, believe me I have been there. I just wish I could find out who's making them so we could all go buy the right parts, but I tried them all when mine was a daily driver and none worked well. JMO.
Pete
Old 12-21-2001, 08:39 PM
Barrier
Barrier's Avatar
I used the "Trico Exact Fit", I think from Autozone or Pep Boys, about $8. each. They are the same size , height as the originals. Work fine on my '86.
Barrier :)
Old 12-21-2001, 09:01 PM
PeteL
PeteL's Avatar
Default Re: Which wiper blades fit. (Barrier)
Yeah, had them. Worked about 3 times then started streaking. You will get pissed off as well, just wait.
To Which wiper blades fit.
Old 12-21-2001, 09:16 PM
Hardcorvette
Hardcorvette's Avatar
St. Jude Donor '06-'07-'08-'09-'10
PIAA the Company that makes auxillary lights, released a Super Silicone Wiper Blade. Priced at 40-45 dollars a pair, they are not cheap but from what I've read abut them, they're the best wiper blade on the market. I plan on getting a pair soon, I'll let you know how they are. :cheers:
Old 12-22-2001, 01:06 AM
Tom Mieczkowski
Tom Mieczkowski's Avatar
A month or two ago I started a thread on Bosch blades and how to fit them to a C4. I also have a LT4 CE and was frustrated with the cost and quality of GM blades. I found that replacing the blades and blade-holders with 21" Bosch worked just fine. The Bosch replacement blade inserts and holders require a very minor trim to clear the hood, which can be neatly done with diagonal cutters. The blade carriers are designed to be used with severaldifferent types of arm attachments, and they fit the Corvette "pin" style perfectly.
I've had mine on for about two or three months and I'm very satisfied. No squeaking or chattering, and the blades are about $6 a pair, or with the complete blade (insert) plus carrier it will cost you about $12.
The long piece I wrote on a step-by-step process on how to do the replacement is probably still recoverable if you do a search under "Bosch Wiper Blades".
Heck, I don't even need to do Rain-X anymore to get the blades to run smoothly.
[Modified by Tom Mieczkowski, 11:08 PM 12/21/2001]
Old 12-22-2001, 02:34 AM
bogus
bogus's Avatar
Default Re: Which wiper blades fit. (Tom Mieczkowski)
from carfan18, I was able to get both wiper arms, and complete blades, with inserts, delivered, for $64.01!!!
The wiper blades are 15.00 each... they include a set of inserts.
Quick Reply: Which wiper blades fit.
