1985 Horn Relay
07-12-2008, 02:20 AM
1985 Horn Relay
Where can I find the horn relay? The manual says center instrument panel. Appreciate any constructive assistance.
07-12-2008, 06:00 AM
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Quote:
Originally Posted by
moserbe
The manual is right. Above the A/C Controll Head and the Radio is the Driver Information Center (DIC). This panel has lights for Door Ajar, Fasten Seat Belts, Security, Brake and things like that. Behind that panel is this:
07-12-2008, 08:08 AM
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Ray is correct.
Remove the DIC, and the relay, as well as the fuse for the horn/alarm system are behind it.
07-12-2008, 09:51 AM
Thanks for the info.
07-12-2008, 01:02 PM
Are you sure the horn relay is bad? If you can hear it clicking, it's usually good. I thought my horn relay was bad, ended up being both horns
Matthew
07-12-2008, 08:21 PM
Matatk
Matthew
I'm getting nothing and have replaced the horns. Hopefully this will work if not ???????????/
07-12-2008, 11:47 PM
moserbe
If it's not the relay there is also a spring and contact under the horn button that can be the source of your problems.
Here's a link to help you start.
http://forums.corvetteforum.com/show...highlight=horn
Matthew
07-13-2008, 01:04 PM
Thanks for the info. I found the fuse was blown after I replaced the relay. The horn sounds like a sissy but at lease I have a horn now.
1985 ,
85 ,
accessing ,
c4 ,
corvette ,
defog ,
fuse ,
horn ,
location ,
pics ,
relay ,
repair ,
replace ,
vette ,
working
