injector videos and questions
Old 10-15-2008, 09:13 PM
DPC Racing
DPC Racing's Avatar
Got it
Old 10-17-2008, 09:56 AM
Sam Lam
Sam Lam's Avatar
Did not notice page #2 on thread and phone number is given above. No need to re-post phone number
Old 10-17-2008, 11:28 PM
H P Bushrod
Moderator
H P Bushrod's Avatar
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Very informative post. I know where I'm buying my injectors from when my LT1 needs them.
Old 11-01-2008, 09:23 AM
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
Default installation instructions
the install instructions are at the bottom of the video page.
Thanks to Bob Lamb "Sam Lam"
Old 11-03-2008, 11:12 AM
08 Crystal Red
08 Crystal Red's Avatar
If you need injectors - call or message Jon. He answered all of my questions, provided great information on his products, got the injectors to me pronto, and got my 90 back on the road.
Thanks Jon!!
Old 11-29-2008, 09:26 PM
RedDwarf
RedDwarf's Avatar
well I can tell you demonstration like that will get my business for sure.I like to see a vendor putting their stuff right out there for everyone to see,and explaining the differences in setups.Also SAM LAM what a beautiful engine compartment that is
Old 11-29-2008, 10:21 PM
Calderone
Calderone's Avatar
let's wait till jon launches his new BLUE DEMON PEARL line !!!
it will definetely kick some *** !
Im getting a set,i will change my Bosch III's for those
can't wait to get my new mods done
Old 02-19-2009, 12:38 AM
ssmith333
4th Gear
ssmith333's Avatar
Default FIC Injectors
Hi All,
I recently purchased a set of the Bosch gen III injectors and installed them in my 1989 vette, I thought i was having a problem with the injectors and I sent Jon a msg for help... after a few minutes and a little trouble shooting (under Jon's direction of course) I was able to pinpoint a timing problem that had nothing to do with the injectors. now the car is running great.
Thanks for your invaluable help...
Spencer
Old 02-25-2009, 12:08 PM
ChrisWhewell
ChrisWhewell's Avatar
Originally Posted by FICINJECTORS
WE RECEIVE SO MANY E MAILS REQUESTING WHERE THESE VIDEOS ARE SO I DECIDED TO PUT THEM ALL ON ONE THREAD.
SPRAY PATTERN COMPARED ON 6 POPULAR INJECTORS USED IN CORVETTES
INJECTOR LEAKDOWN RATE
TYPICAL MULTEC FAILURE
MORE BAD MULTECS (COMMON PROBLEM)
HOW TO OHM CHECK YOU INJECTORS
FLOW MATCHED BOSCH III FOR CORVETTE
85-88 STOCK BOSCH COMPARED TO THE DESIGN III BOSCH
EARLY BOSCH DESIGN II COMPARED TO DESIGN III BOSCH
LUCAS DISC VS BOSCH (BOTH NEW 30’S SPRAY PATTEN DIFFERENCE)
STOCK MULTEC COMPARED TO LUCAS DISC AND TO BOSCH DESIGN III 22lb
STOCK LT1 24lb compared to BOSCH III 24 LB
FUEL INJECTOR IN SLOW MOTION
CUSTOM INJECTOR SIZING FOR PERFORMANCE ENGINES
FOR CROSSFIRE 84'S ONLY
detailed installation instructions provided by "sam lamb"
http://webpages.charter.net/buddiel/...al)%201-04.doc
Nice videos.
I'd be curious to see the droplet size distribution and average droplet size for a given injector at varying fuel pressures through that injector.
One method for doing this would be to provide a dye in the fuel, and direct the output of an injector under conditions being tested onto a moving substrate. Imagine a bench-top belt sander, but the belt is not sandpaper, rather, just a piece of paper. With the speed of the belt adjusted appropriately, the injector dispensing the dyed fuel could be directed at the moving "belt" and opened for one cycle, the injector being appropriately-distanced from the moving belt substrate.
Then, the belt is removed and dried, and individual droplets per area are counted, as well as the size of the droplets measured for a selected sample area on the belt.
By repeating this with different injectors, at different fuel pressures, one could arrive at the "best" conditions for a given injector.
Old 03-02-2009, 10:31 AM
gevans
gevans's Avatar
Default Recommend FIC fo Fuel Injectors!
I purchased a set FIC Bosh III injectors for my poorly running, hesitating 91 vette. FIC was so helpful and had great customer support! Injectors are installed and my 91 vette is running fantastic! Thanks so much! I HIGHLY recommend FIC!!
Old 03-02-2009, 12:43 PM
Calderone
Calderone's Avatar
me2 !!!!!
Old 03-09-2009, 09:24 AM
riksdodgydeals
riksdodgydeals's Avatar
i cant see the videos, i dont know whether its just my work pc tho
Old 03-09-2009, 09:54 AM
  #33
FICINJECTORS
Supporting Vendor
you got to download the plug-ins for your browser
Old 03-09-2009, 11:36 AM
  #34
riksdodgydeals
thanks, i'll give it a go at home then
Old 03-29-2009, 11:09 AM
  #35
keithfromindy
Cruising
keithfromindy's Avatar
Those are my FIs in the "FOR CROSSFIRE '84s ONLY"
My car has been running better than EVER...thanks to John and his service.
Just to get the whole fuel system back to new, I replaced the fuel pump, filter and had John rebuild the injectors. It was Johns work that got my '84 TBI purring like a kitten, except when I punch her, when she roars like a lion. Thanks again, John.
Old 03-29-2009, 11:23 AM
  #36
FICINJECTORS
Supporting Vendor
The service for TBI is 75.00 complete with all gaskets and seals needed to reinstall them. Every TBI injector we get in either leaks or is performing way below original specs. We restore these to 100% of original spec. This should be part of EVERY tune up on a 84. Removal of the injectors is cake, Turn around is 24hrs. We also rebuild the complete throttle body if needed.
Old 04-16-2009, 04:26 PM
  #37
rickneworleansla
rickneworleansla's Avatar
Nice post and video!
I am currently using bosch 24# SVO blue tops that I upgraded to when I added the nitrous kit a couple years ago. Have you tested those? Any opinions? I'm upgrading my heads next year and may need to upgrade the injectors. I was looking at the new Racetronic 37# injectors. Any idea who makes those? I'll be sure to give you a call first when I'm ready.
thanks
To injector videos and questions
Old 04-16-2009, 07:43 PM
  #38
FICINJECTORS
Supporting Vendor
thanks
Rick call me before you do anything. we sell those 37's too. They are SMP same as accell, etc. I rather see you get a Bosch 3 36 and we will even trade back in the SVO 24
Jon
Old 04-23-2009, 10:56 PM
  #39
Jetts4u2
Jetts4u2's Avatar
So, with an adjustable fuel regulator, will a set of bosch type III 19 lb injectors work in an L-98 corvette?
Old 06-29-2009, 11:04 PM
  #40
captain cook
captain cook's Avatar
My 1992 corvette just sprang a leak in a fuel injector. What is the right injector? Where can I buy the right one?
Quick Reply: injector videos and questions
