Opti Spark Plug Wire Sequence
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Can any one tell me the sequence for the cylinders as they connect to the Opti Spark
ie cylinder 1 is bottom of the DS opti ect...
Tks
Chip
Tks
Chip
I'm in the process of changing my opti now and can tell you for sure when i get home (at work now) but i know on both the new and the factory opti the plug numbers are molded into the opti cap next to each wire connection.
This topic came up recently. In the past week or so, someone posted a graph of how they install.
If the SEARCH function is working, give it a try; you should be able to find his post.
Jake
Jake
