Rear Axle Gear Ratio Question
Cruising
K guys I'm looking for a gear change myself, I just put a fresh 355 with 10-1 comp 555 lift cam, ported aluminum L-98 heads, roller rockers, single plain intake, 750 holley carb, an 2500 stall but flash almost 3.
Problem: I was planning on just hoping out on the street an just nailing it an blowing the tires off as long as i wanted but seems like the car is little sluggish an doesn't spin at all does pull decent. btw its a 86 a/t but came with the aluminum heads, This cars is mostly street an strip toy.. NOt worried about gas
it is like 1200 for a shop to do your rearend! up to you!
i am looking for a stoplight warrior also - everyone keeps telling me that i will have a humm or sound from the change due to aftermarket parts. how bad is this "sound"? i took it in this morning so hopefully i reply with results in two days....
Received 1,401 Likes
If the gearset is installed properly it should not make a sound, this is why this job is best left to an experienced professional.
keep us posted on what happens!
i took it to a ring & pinion shop which is all they do - and he even saidthat there will be some sort of humm. we shall see hoping to get it tomorrow i am stoked regardless!!!!!
I have heard that non stock gears will have a noise of a sort! some boil them all sorts of lil tricks to try to quiet them, but since people have been doing gears in c4's the overall concensus is there will be a noise.
3.07 gear ratio in a 1984 Corvette
Pro Mechanic
3.07 is probably just fin for that car. If you want "more", then the place to look would be converter, ported intake, tuning, and exhaust from the head to the tip.
After all that, then more gear would help.
I checked my RPO codes on my 1984 Corvette - 52000 miles and it says it has a 3.07 gear ratio I used to own a1998 and I know that the 1984 is much slower. is 3.07 a good gear ratio to have in a 84 Corvette? from what I hear it's better than 2.59 I just wanted to be a little bit closer to the 1998 Corvette that I used to own in performance however everything else about this 84 is much better just seems more solid than my C5 I used to own
Pro Mechanic
#33
Pro Mechanic
#34
With slightly more than 400 units mentioned I believe it was maybe just an "oversight" in the marketing brochures/spec sheets for the car. Part of a package? I don't believe OR I should say I've never seen it mentioned.
If most of the NEW '84 buyers knew of the ratio option I'd have thought there would have been many "thousands" of units.
I don't know that CFI-EFI's car actually was a 3.31 (GW4) but I certainly do miss the guy. Entertaining he was!! YES TOM RIP CFI-EFI !!!!
#35
#36
