Anti-theft system
Old 10-04-2008, 05:40 PM
Tobben
5th Gear
Tobben's Avatar
Default Anti-theft system
Hi i'm buying a corvette c4 next week, it has electronical anti-theft system problems. Does anyone have a link to any wiring diagrams for it? I'm norwegian so my english may be a little weird
The system is supposed to be disconnected, but the car still have starting problems, they suspect it's the anti-theft system. I haven't received the vette yet, never been in one actually, but does it have a diagnosis stick?
Old 10-04-2008, 07:20 PM
86PACER
86PACER's Avatar
Does the starter spin?
If the starter does nothing, jump battery voltage directly to it and see if it spins. If it does, there is a problem in the VATS.
If not, the starter is dead.
http://www.vatssucks.com/
Old 10-05-2008, 07:04 AM
Tobben
5th Gear
Tobben's Avatar
The car starts if i jump directly to the starter but it stops within seconds.
Old 10-05-2008, 07:20 AM
86PACER
86PACER's Avatar
What year is this car?
Old 10-06-2008, 03:44 AM
Tobben
5th Gear
Tobben's Avatar
Should probably mention that earlier, but forgot. If it has OBDII stick, where is it located?
I'm getting the car next weekend, but i want to be ready for it.
Old 10-11-2008, 09:50 PM
Tobben
5th Gear
Tobben's Avatar
I got my C4 today, i'm so happy. What a ride, but it doesn't start. I notice the key were lacking the transponder unit on the key. Isn't the vette key supposed to have such a thing? If the ignition unit on the steering colon doesn't reconise the key, it wouldn't start right? The anti-theft system is supposed to be disconnected, but after a while the vette didn't start- according a previouse owner, but if the anti-theft system is reconnected. The key need to have a transponder unit on the key, or? Next week once i'm on my job, i will try to rent a computer with the right program to read out diagnosis fault. If there are any fault pointing toward the key, i will probably change the key. Does the key need programing to work? My suggest would be yes, but...?
To Anti-theft system
Quick Reply: Anti-theft system
