1985 antenna mast replacement kit
Does anyone have a copy or link on how to replace the antenna mast with a repair kit for a 1985?
I have the old antenna tube out, my question is how does the old chrome antenna mast come out of the tube?
From the top?
From the bottom?
Do I need to take anything else off the antenna tube to remove the mast?
Do I have to drill out any dimpled areas?
From the top?
From the bottom?
You have to drill out the rivets, so you can seperate the halves. Use machine screws/nuts to replace rivets.
http://members.shaw.ca/agent86/Power%20Antenna.pdf
