C5 caliper bracket adapter for C4
Old 08-11-2009, 09:46 PM
tpi 421 vette
tpi 421 vette's Avatar
Default C5 caliper bracket adapter for C4
Who makes a caliper bracket adapter to put C5 brakes on a C4. I ended up with some 2002 C5 brakes, and I heard they are a upgrade for our cars. The calipers look like they have bigger pistons, and say Corvette on the calipers. I will be posting the brakes for sale soon. I have everything front and rear... calipers, rotors, pads with 75% of the pad left, and even the hoses. Thanks.
Old 08-11-2009, 10:53 PM
cumbercr
cumbercr's Avatar
There was a guy here on the forum that fabricates the adapters. But he only does the front brakes. I've also seen some advertised on line.
Old 08-11-2009, 10:54 PM
tpi 421 vette
The rear brakes wouldn't work on C4's. The emergency brake set up is different.
Old 08-11-2009, 11:07 PM
scorp508
scorp508's Avatar
That's assuming you want the parking brake at all. I've heard of some folks retrofitting it to work with the newer style, but I don't have the details of how.
Old 08-12-2009, 05:14 AM
worldsaway
worldsaway's Avatar
I have a set of C5 to C4 abutment brackets I bought from PNW ZR-1 that fit 88-96, I never installed them. Let me know if you're interested. Ed
Old 08-12-2009, 05:45 AM
93 ragtop
93 ragtop's Avatar
Jim, make sure they will fit under your wheels. Its my understanding that they wont fit under sawblade 17in wheels, much less a 15in wheel. I dont know what wheels you are running, but being your avitar shows 9sec. I doubt your wheels are stock!!
Old 08-12-2009, 10:01 AM
87Z-ya
87Z-ya's Avatar
PnwZr1 (Jeff) Sells a very nice kit at a good price for this swap.
The C5 calipers are a great improvement over even the 13" C4 setup, and the c5 rotors are about 1/2 the cost. I made a DXF file for the brkts and cut some out on our waterjet for my swap.
If you are only drag racing your car I would stick with the 12"c4 setup, there is about a 15lb diff, and with a good pad, they will do the job just fine.
Oh and the C5 calipers will fit with 9.5" sawblades and a 5mm spacer.
Old 08-12-2009, 10:47 AM
tpi 421 vette
I wasn't going to put them on my car, I was going to put them up for sale. I just wanted to let whoever buys them where they can get the things to make them work on a C4. I have J55 13" rotors on my car now. If anything, I would like to put some light weight drag brakes on my car.
Old 08-12-2009, 02:51 PM
tpi 421 vette
Anybody have any idea what a complete C5 front brake set up is worth. Rotors which look good, pads have 75-80% left, calipers, and brake hoses?
To C5 caliper bracket adapter for C4
Quick Reply: C5 caliper bracket adapter for C4
